19x10 or 19x11
bahasad
Somewhereinamerica
17 GT Premium, 14 BMW F30 Stage 1
So my mustang black accent package wheels were stolen off the car, and I'm trying to replace the setup. I would like something cost effective, wide, light, and reasonable quality. The car is lowered about 1" on Ford track suspension setup and it has 25 mm spacers in the rear, 20 mm in the front. I don't want to take off spacers or roll fenders.
Would I be able to pull a 19x11 all around? or should i stick with the tried and true 19x10 on 285/30 tires?
Looking at SVE S350 wheels or AMR 19x10 Black wheels.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
That's a bummer!
Feel free to check out project6gr.com
Best Mustang fitment / Lightweight, Strong structure quality (track proven)
Sizes are 19x10 / 19x11
We also provide lugs and wheel locks to prevent anyone from stealing your new set of wheels.
I would recommend sticking to 19x10 285's for a direct fit.
PM us for special 6G member pricing! :)
jasonstang
Denver, CO
2017 GB GT/CS 6MT
The problem with 11 all around is if you want flush in the back, it will rub in the front unless you use different offset which defeats the purpose of using all same size wheels.
With aftermarket wheels you need to take spacers off because most of them are spaced for Mustangs.
Those spacers are only for stock wheels.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
First off im sorry to hear about that brotha.
Now You can do the 19x10 on 285 tires without issue 285/35/19 is the sizing I recommend.
You can also do a 19x11 front and back use a 25 mm adapter upfront or what most of my clients do is switch to 3" studs 305 tires all around.
SR56
Orlando, FL
seanrooney.realtor
Sean
2016 GT PP
I was able to go 295/35 w/ 19x10 & +35 no issues and no spacers.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
I want to talk about tires.
For the setup
275/40/19 to 305/35/19 for the 19x10
For the 19x11 295/35/19 to 345/30/19
Andrewg
Sun, Sea, Sand and Camels
Dubai, U.A.E.
Andy
2015 Guard Metallic GT 401A
For the setup
345/30/19 on a 19x11 fits ok? Always thought a 325 would be a stretch on the 11".
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Yes sir it does haha we have been doing a good bit of setups like that ourselves.
One of our shop cars runs the P51 101RF wheels 19x10/11.5 with 295/30/19 R888R fronts and 345/30/19 R888R tires no modifications needed just some camber adjustment and shes lowered 2" all around.
TooSoonJunior
Southern CT
2015 Mustang GT PP M6
Do you have pics of that setup? Sounds like a badass street tire combo
draconis123
Michael
2016 GT
This is great info. Thanks.
Question though, what kind of offset would I need to run 19x11 in front with a 25mm spacer? I already have spacers and would upgrade eventually to the 3" studs. I'm looking at the SVE R350 wheels with a 50mm offset.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
A 50mm offset would be idea-able with the 25mm spacer.
Here is a GT on 19x11 50MM squared track setup with a spacer.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Typically ET 50 and rock the 25 mm front spacer with the 3" studs and your solid it works.
Ya actually brotha if you check out our IG
PKautodesign
LAStreetCars
We have images posted of our shop car there.
