Vroom
- Jan 25, 2019
- Houston, TX
- 2016 Mustang GT
I got tired of searching for something affordable to have fun in and wanted a project, so i got desperate as can be and bought a really cheap 2016 base mustang GT at auction that was probably headed for a scrap yard. Did not know it had a good engine so i got lucky there, but even then it still possibly should have been scrapped. Story behind it is there was a large amount of flooding in FT worth TX and someone drove it across a flooded bridge with moving water at which point the driver had to be saved by breaking the driver side glass as it floated away sinking to the bottom. The muddy flood water piled inside that window covering everything inside with mud and destroying every bit of the electronics. Nothing survived inside, but the frame was completely straight and "only" required new electronics, ongoing bodywork, and a few nonessential upgrades to get going. I work a full time job so progress has been slow but i got it running in a month and within 5 months mostly road worthy with no codes or drive-ability issues besides abs and stabilatrac issues(no nannies). It is still a work in progress and needs a lot more work as soon as the $ permits. Still using a gross flood seat and cracked/bent hood for now.
The rebuild/build?:
-Cleaned thoroughly and Disassembled taking loads of pictures to help me put it back together
-shot water out of the plug holes of every cylinder by turning crank manually without spark plugs in.
-Drained all the water in engine oil, 6 speed trans, and rear differential "there was alot"
-New fluids in all of vehicle, slowly turned engine manually clockwise at the crank squirting small amounts of oil to work cylinders for a few days
-2017 Coils and PP engine harness(had correct coil plugs and oil pressure sender unit wiring)
-Premium PP Front Engine Bay Harness(used correct version besides not having rain sensor fuse...so i need to splice or replace again)
-Removed/Reused Dash and modified vents for PP guages, PP HVAC duct swapped, Premium PP dash wiring harness
-Upgraded to Dual zone climate(premium) HVAC unit, its that big sob behind dash.
-PP Gauges, PP rear diff temp sensor, PP oil sender unit
-Rear body loom from dash to rear replaced (wrong one used... replacing with a premium package version soon costs alot of $$$)
-Carpet and inner firewall insulation pad replaced
-Headlight replaced
-fog lights and front bezels bought
-Front and rear bumper replaced
-Front valence and new splash shields
-Rear bumper and its wiring harness replaced
-Replaced every module from front to back.
-Premium Center dash controls/bezel
-Sync3 unit, usb module, gps antenna added "backward under dash lol, base gt's dont have roof hole"
-Donor car ECU/PCM with keys, dash display, & body/security modules (was important to get from a single car because i couldn't go to dealer to get them reprogrammed easily. these have to match each other).
-Driver door & glove box re-keyed to match donor cars key set
-Maintained the existing 3.55 rear diff gears
-Ford performance starter
-Battery
-ABS module was swapped but the module i swapped it with wasn't communicating so i need a to buy another PP module. (edit: i ended up using my original base GT ABS module, these things are waterproof, edited hexidecimal location for VIN & options to match donor parts and i was good to go with zero abs lights, steering modes & cruise all functioning. - the modules are not cross compatible with the pump section of abs system.)
Fun stuff:
2018 GT intake manifold with plug and play harness for imrc's
Ford's LU47 injectors to run E85
Roush CAI Intake without insert
Lund Tune
JLT Catch Can
Cervini Side exit exhaust "didnt use body skirts"
Anderson Composites carbon fiber GT350 look side skirts
Fun facts:
- Concerning fluids: The coolant and brake fluid were only things uncontaminated with water.
- The only electronics to survive were the alternator, windshield wiper motor, steering rack, one headlight due to other being cracked, both taillights, rear taillight module(replaced regardless), door modules, ABS module. All of the wiring itself was salvageable but i opted just to replace it due to corrosion concerns.
-The old intake manifold was bad(EDIT: May have just been gearing was 3.55 when computer was looking for 3.73 gears so it was pulling power in certain RPMs throwing misfire codes), which i assumed was due to dirt in vacuum lines or broken imrc valve shafts, caused quite a few misfire codes which in turn caused quite a few empty jack D bottles.
- i realize this was way too expensive and i should have just bought a mustang but i learned everything about these cars, so it was a learning experience and if anyone needs help ever just ask. If anyone ever does this just buy a complete wrecked donor car, it will be cheaper.
The "flood or submarine Stang" started at first try running a bit rough and took quite a few days/months of swearing, compression tests, days of disappointment, and mostly days of excitement which is why I/we do this. This thing runs so damn good i see why its loved. Desperately need seats, hood, stickier tires/ and wider wheels. I will post more pictures of the process later, and possibly a write up along the way about all the modules, part numbers and how best to attempt this task for anyone in future
The rebuild/build?:
-Headlight replaced
-Battery
Fun stuff:
Lund Tune
JLT Catch Can
Fun facts:
