Do you see any score marks on the LT?
Does your front struts or the back of the front tire/rim have any witness/rub marks?
I didn’t notice anything touching but I’ll check the AC hardline when I get a chance.It's hard to diagnose/tell from the vids what is making the noise. The vid of the LT's and steering shaft, it does not look like they are touching when sitting there. However when the car is moving/engine running and the steering shaft is being moved it only takes a slight bit of flex of the motor mounts or shaft to allow contact with a primary tube of the header on that side. Again, hard to say from seeing the vids.
Have you had a chance check the back sides of your wheels and also any suspension parts behind them for any witness marks/scoring?
If you can have a shop put it on a lift with the car at idle, and someone cranking the steely the wheel L or R, you might be able to see if the steering shaft rubs or touches a primary tube at all.
I know you're saying you get the noise when turning the wheel, but again there's other movement going on in the engine bay as well as vibrations when driving/steering. On the passenger side, it's a very tight fit with aftermarket headers and the A/C hardline. It's been a known problem where the A/C hard line rattles against a primary tube of the header or rattles against the strut tower. See if the A/C hardline is touching anything. If it is, either try to CAREFULLY move it in a direction away from the object OR using a zip tie try tying up the A/C line to avoid rattles.
I’m hoping it’s the control arms. It makes this sound with the car in park with just moving the steering wheel and I believe in just one direction. Thank you I will pick that up !Sounds like a dry balljoint or tie rod end to me, or maybe one of the strut bearing plates
Perfect, Now remove those self tapping screws and replace with a proper bolt and locking nut or lock washer and nut@SheepDog @Cobra Jet @RacingRoger
I found it! Brenspeed used large screws to install the fuel system gauge and it was rubbing on the spring!
