10:1 compression gen 2
Basspro302
Ohio
2019 mustang gt
Just a thought the more compression the bigger pulley you can run to make the same power. Less chance of belt slip and dealing with 10rib kits and overdrive crank pulleys. As you have a vortec kit I would have gone with factory compression.
I would consult whoever is tuning the car tho
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Haha ikr. I'm gonna say not serious
You'd be wrong. This isn't the 70's guy. Some of yous seem to think coyotes have top fuel over square size cylinders, huge and lazy intake ports/exhaust port. Not the case. More boost, the more restriction, and the more heat.
engineermike
La
2018 GTPP A10
I'd like to see 2 all out builds. One at 12 to 1 and one at 9 to 1. If the 12 to 1 engine could support the same amount of boost and being able to use MBT the 12 would win. But can you use MBT even with E85 and 30 Lbs of boost?
That’s easy, just compare gt350 to gt500 builds. The bore, stroke, heads, cams, etc are all very close if not identical, but one has 9.5/1 and the other 12/1.
Jackson1320
California
Jaxson
2015 mustang gt
You are correct with more compression you will not need as much boost to make the same power so you can run a larger pulley and not worry about slip. There are pros and cons though. It’s not all pros
Nawsad123
Everett
Bonez
2017 Mustang GT
I have the aluminator crate motor sc 9.5:1 compression. Lower compression means more boost (ie smaller pulley) and tuned to e85. Thatll be your 750 to the wheel no problem
Wheysted
Canada
15 mustang gt
What kind of power are you making ? Did you notice a difference. How much more boost did you have to add to compensate?
Nawsad123
Everett
Bonez
2017 Mustang GT
On the stock motor, made 680 to the wheel. Still breaking in this new motor, but will be putting on a 3.33 pulley to compensate abd increase boost by about 3-4 psi, all on pump gas. I should be back to the 680, if not slightly above
engineermike
La
2018 GTPP A10
When dropping from 11 to 10, you should expect to lose about 4% of your torque. 1-1.5 psi will restore that, but even at the same power level the result will be lower peak cylinder pressure and engine stresses.
Wheysted
Canada
15 mustang gt
Okie that's good go know :) probably gonna run a 3.3 on pump and 3.1 on e85
