AutoWeek Review (GT)
Tony Alonso
Super Moderator
Moderator
Cincinnati, OH USA
'01/'09/'19 Bullitt, '90 GT, '00 Corvette FRC
http://autoweek.com/article/car-rev...g-first-drive?utm_source=BreakingNews20140917
Our first drive was with the 5.0 with manual transmission but no Performance Pack. We drove on some of our favorite roads in SoCal (how did Ford know?). How was it to drive the new Mustang? It was surprisingly good. Very good. So much better than any Mustang you’ve ever driven. It wasn’t just the new independent rear that made the difference, though that was certainly a huge part of it. It was that all the inputs you receive in the driver’s seat were tuned to eliminate all the stuff you don’t need to know about. It wasn’t isolated, just refined. Everything from the noise that comes into the cabin to the feel through the steering wheel is far ahead of old Mustangs. It’s still more of a muscle car than it is a sports car, but it’s one of the most refined muscle cars you’ll see
Our drive was up Angeles Crest Highway, down Big Tujunga Canyon and back into the city. These are wider-open, faster fourth-gear turns for the most part, and on them the new Mustang simply hunkered down and cornered better than the old 'Stang ever could. And it took them so smoothly -– ease into the corner under braking and ease out under glorious V8 power. The six-speed Getrag was easy and quick to shift, though we weren’t able to be completely smooth about clutch engagement and takeup. Over the bumps, the independent rear not only soaked up every road irregularity it came across but allowed for easier application of power upon exiting. There were many times in corners when we uttered words like “Superb!” and “Magical!” That might have been as juxtaposed with the old Mustang, but it’s still an impressive ride.
We had the stock suspension, too. That was soft enough in city driving and over the rough pavement of Angeles Crest. But when we got on shorter, tighter turns and pushed it even harder, we could feel the all-season 255/40ZR-19 Pirelli P Zero Neros starting to give way a little more easily than we would have preferred. In particular, we could get them to understeer on the tightest corners. There’s a solution to that in the Performance Pack suspension. With that, you get higher spring rates, bigger rear stabilizer bar, unique damping that is higher front and rear, rear monotube shocks and staggered-fitment P Zero Summer tires with 255/40R-19s front and 275/40R-19s rear. You also get a 3.73 Torsen differential and front six-piston Brembos with 380-mm rotors. And on top of that, the Performance Pack gets a bunch of bolt-on structure pieces to stiffen the chassis further: stiffer front strut mounts, and the front lateral link instead of a bushing gets a cross axis joint to stiffen up front lateral link significantly. We didn’t drive that car yet.
Nor did we drive the much-heralded four-banger. Ford is proud of this little engine and rightly so: Through dual-scroll turbocharging and direct injection, engineers extracted 310 hp and 320 lb-ft of torque. Ford claimed that there was no lag on the four-banger’s turbo, and after a good run, we're inclined to agree. While this engine is shared with the Lincoln MKC, it is refined to take advantage of its longitudinal placement in the Mustang, with longer intake runners. A look at a four-cylinder on an engine stand showed the lack of an exhaust manifold, with runners cast into the block routing gasses directly to the turbo.
And no, we didn’t get to drive the 3.7-liter V6, which peaks at 300 hp and 280 lb-ft of torque. That wasn’t even available for the intro program at all. We think Ford really wants to push that EcoBoost engine.
That’s all we have for you so far today. We’re heading out now to drive a four-cylinder Mustang. We’ll have more on that car tomorrow.
StangFX
Guest
"So much better than any Mustang you’ve ever driven. It wasn’t just the new independent rear that made the difference, though that was certainly a huge part of it. It was that all the inputs you receive in the driver’s seat were tuned to eliminate all the stuff you don’t need to know about. It wasn’t isolated, just refined."
Great review, especially for a base GT.
RevvdMedia
Canada
2015 Mustang GT Premium
Reading now. Excited to see opinions on base GT...since everything else is PP.
leftywayn
Past Mustangs
Mazda3
This is positive, but then it becomes a marketing piece.
Oh No... I better order the Performance Package.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Sweet, now where's my car.
