z06psi
- May 15, 2015
- Evans, GA.
- Andrew
- The pot stirrer
I will try and document everything I do as I go through this install.
I have the Shaker 12 speaker system. I will replace everything pretty much besides the factory head unit.
JL Audio (FiX86, TwK88, 1000/1, 800/8)
Rockford Fosgate (2x10" P3 DVC 2 ohm shallow, all wiring)
Morel (3 way components. Haven't decided which ones)
I am going to retain the OEM center channel but change the driver.
Only thing not purchased is the front stage. The two 10s will be in separate boxes on each side of the trunk made with custom fiber-glassed enclosures made by me. The amp rack will be under the back deck. Loss of trunk space will be kept to a minimum.
This will happen over the next two to three months. I will update with pics and descriptions as I go. Everything will be soldered or use factory style connectors.
