J.P.B.
The basic question:
Given comparable costs, should I upgrade the FMIC (looking at the ATM intercooler), or add water/meth injection (with NO change in the tune)?
The car:
- 2015 ecoboost mustang with the FP ProCal tune and CAI. I also run the NGK LTR7IX-11 (6510; 1-step colder) plugs and a UPR crankcase breather, but I expect that the plugs and breather are trivial factors. It’s a manual transmission car with 3:31 gears, and I can do 0-60 in 5.2 seconds.
How I use the car:
- The daily drive this car for most of the year. I also do track days at my local track (AMP: 1.6 mile road course with 11 turns) as frequently as I can. I have upgraded brakes, and I run square stance 275 tires.
Perceived pros and cons of upgrading the FMIC:
- Benefits can be achieved without a tune.
- Make expected power under a wider range of conditions by cooling pressurized air; the ECU being less likely to retard timing.
- Decease risk of pre-ignition (through cooling).
- Increase in weight over stock FMIC. [con]
- Possible increase in lag? [con]
- Still octane limited. [con]
Perceived pros and cons of water/meth injection (assume no change in the ECM tune)
- Snow performance claims benefits can be achieved without a tune.
- Decrease temperature by up to 100 degrees more than a FMIC (?)
- Decease risk of pre-ignition.
- I am stuck with 91 octane pump gas; with 50/50 mix, octane could be approx 116?
- With high octane, presumably the limitations imposed by the ECU for 91 pump gas will be lifted, timing will be advanced, and hp gains will be realized?
- Valve cleaning?
- Extend engine life?
- The water/meth reservoir has to be refilled. [con]
- Possibly impact warranty. [con]
Based on the how I perceive the pros and cons, I think the water/meth injection might come out on top. But this is my first turbocharged car, so I am looking for advice from those with more experience. I am also relying quite a lot on the Snow Performance promotional material, and I have not met anyone with direct experience with WMI who has not tuned the car to take advantage of it.
Also, I did try to find a thread that covered this. If you know of one, please point me in that direction.
Many many thanks in advance.
The car:
How I use the car:
- Valve cleaning?
