Broken down
GR11M
Herts, England
Graham
Ford Mustang GT
I was driving along and saw light smoke coming out the back, so pulled over when I could get onto a quieter road. Looked under the car and saw oil pouring out and the coolant has dropped from max to min, but luckily engine temp was normal. Currently waiting for the RAC :(
EDIT:
Here's a few pics from last night
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
who knows, only had the headers done a few weeks ago
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
The actual build date was Nov 2015.
looks to be more oil on the passenger side of the engine.
hinch
uk
Sideways
that'll be the oil cooler shitting itsself.
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
Luckily I work next to Ford, just hope they don't moan about the mods.
SteveS
...Bon Scott Land...
Bon Scott Land
Mustang GT Magnetic
If it's the oil cooler it should be a known fault and nothing to do with mods.
Bad luck. Hope its a quick fix for you :(
Jimboy2
Denmead, Waterlooville
Mazda Mx5 :(
100% oil cooler. Should be a quick fix. Make sure you let them know exactly what you know. It needs flushing A LOT it will need a new coolant tank as it's probably stained. You should have the car back and repaired by Friday at the very latest. If they need pointers tell them to speak to Paul at Hendy Eastleigh and ask them about Mr Leeks car
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
Coolants not stained, its still pink, got a Mishimoto coolant tank.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Your oil cooler has failed, seems similar fashion to mine, where it just mainly drops the engine oil on the road, there could still be minor coolant contamination but nothing major. In short ask for:
- New oil cooler and gasket installed (2 days max to order now)
- Fresh oil change, new oil and new filter
- A full coolant system flush as per Ford guidelines (special cleaner for our engine that Ford have very few typical at given time but can get it within a day.
- New coolant
- Full clean of the underside and pressure wash and brake cleaner the hell out of subframe and underside of car.
Hope they turn it around fast.
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
There's oil everywhere, mostly under the car and up the boot, with sum on the passenger side of the engine bay.
Still got another 40 mins till the tow truck is here, luckily I'm only about 10 mins from Ford.
Gibbo205
UK
Wind blows it everywhere, how much oil on the dip stick level?
slowhand99
Surrey, England
Ben
Mustang GT Vert Race Red ord 26/03/15 del 24/03/16
Come on [MENTION=18365]Andy Barratt[/MENTION] this is too much. A known faulty batch, multiple failures, potential for engine fire, road and tyre contamination possibly causing an accident and probable engine damage. Why no recall?
