Wheel Spacers. 20mm or 25mm?????
Fordever
NL, Canada
Derek
2016 GT/CS Convertible
Wondering which would look better? I have a Cali Special with factory 8.5" rims and the tires are 255-40-19.
I have looked at lots of setups and some 25mm spacers seem to make the tires stick out more on some cars than others. I am assuming it because of different tire and rim setup.
I want flush-ish or even tucked in a "LITTLE".
Which should I get, if I do decide???:shrug:
jbailer
Joe
Personally I think 20mm would look better but you'll need to go at least 23mm if you don't want to have to cut the factory studs down a little to keep them from hitting the back of the wheel.
Fordever
Fordever
NL, Canada
Derek
Whats your setup?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
20 should work with your wheels and will look better.
jbailer
Joe
Whats your setup?
Mine are 25mm front and rear on the stock 19x9 PP EB wheels. The front is fine, the back is just a little wider than I would like.
CJRogue
Driver
Tennessee
TBD
Are there any downsides to spacers? I'd like to widen the stance on my '15 GT 50th appearance wheels too.
Fordever
Fordever
NL, Canada
Derek
I think yours look great. So, maybe 25mm is good for me :cheers:
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
I've got a set of 4 25mm arriving this week. My back wheels have a bit of negative camber so I hope that'll tuck them in the few mm's needed so they don't do as jbailer says.
jbailer
Joe
It's fine really. If I remember right, I have my back camber at -1 or -2*. The wheel itself is not past the fender but the tire bulge is. I just think a 20mm in the rear would be enough that it would be just inside. I've never had a problem with it rubbing or hitting and I'm not gentle. I corner very hard and not afraid of bumps. It's more a preference of looks, it is aggressive though.
Mustang_Lou
Toronto, Canada
I agree on the looks part. If I feel the tire bulges too much I'll buy a thinner set for the back.
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
For those running PP wheels, Motorsport Tech makes a 23mm for the rear, still clears the lugs, but tucks the wheel in just a _tad_ more.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
I would say 23 mm all around, The above mentioned company has them, we also make them on order with the studs pressed in.
Only downside is this, dont get a bad quality spacer, ensure the product you are getting is proper in material and construction and youll be fine. Oh and dont overtorque the nuts please.
MaskedRacerX
Driver
Vilano Beach, FL
DT
Holy smokes, I can't agree with this enough. This is the part, that's holding on your wheels, that supports the weight of the car ...
I know, let me get some random parts from Ebay :lol:
Mustang_Lou
Toronto, Canada
Thanks for that ... the make 20, 23, & 25mm. Pricey at $65 each mind you.
MaskedRacerX
Driver
Vilano Beach, FL
DT
Yeah, the MoSpo Tech are pricey, but use ultra high quality materials, lifetime warranty - they had a killer Group Purchase last year, but I actually scored mine lightly used.
Here's how it sits - note I also just added some CPC splash guards, that are highly recommended - any splash guards, though these are solid product too:
