Where to buy 25mm wheel spacers?
Blacktop17
CT
2017 GT , 1986 GT
Where is everyone buying slip on 25mm wheel spacers in black? I found 20mm in black at CJ pony for $41.99 pair. They dont carry 25mm. I can find 25mm on other sites for $150 +. Can't see paying 4x more for somthing only 5mm thicker and made from the same material.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
1blkpny
North dakota
2017 mustang GT premium
Be careful of buying cheap ones. You have to realize that they are cheaper because of less quality in materials they are made from. I have the set that was shown on amazon in the other post. That price is for a pair so 100 for 4. there are other posts on here talking quality. There are some things that spending a little more on might save you down the road.
Nagare
Ft Lauderdale
Be careful buying expensive ones, they are more expensive because of branding and not necessarily indicative of any quality increase. I ran those for a year with no issues and plenty have run them longer. Spacers always bring a lot of different opinions, so that's all I'll say on it.
Blacktop17
Blacktop17
CT
2017 GT , 1986 GT
Isn't 6061 t6 billet aluminum and 6061 t6 billet aluminum the same material?
Blacktop17
Blacktop17
CT
2017 GT , 1986 GT
1blkpny
North dakota
If you would read on my post I said I was running the ones that you have posted from amazon. They are quality spacers. I was referring to some of the cheap ones on ebay and other sites. That was what I was referring to. Thanks much
Nagare
Ft Lauderdale
Those arent "Slip-on".
Keep in mind that you'll want longer studs if you're running bigger than a 5mm spacer. You want at least 5 full turns for the lug nuts and that just won't happen with much bigger than a 5mm spacer.
Fair enough, kinda missed that part of the line!
Blacktop17
Blacktop17
CT
2017 GT , 1986 GT
The reason they don't have a slip on model is you wouldn't have enough stud left to hold the wheel on.
I believe you run out of stud around 5-7mm and they do sell slip-on spacers bigger than that. Anyway I have ARP studs so not worried.
Du_tch
Glendale California
Hovsep
2017 Mustang GT, 2012 F-150 5.0
Opmustang.com for the best spacers
Blacktop17
Blacktop17
CT
2017 GT , 1986 GT
Opmustang has been out of stock on there spacers. Went Adaptec
