Here is the pass that it broke on. lolHey, Kelly, didn't you know - more wheelspin will prevent that!
Title: Cast Iron Diff Housings don't just belong in manual trans carsI am a little confused with regards to the title.
Especially as someone is who looking to swap out there cast iron dif on a manual car.
So you swapped in a Aluminum dif in a a Manual GT car; broke it. Then put a cast Iron one back in it held up for at least three passes; however you proceeded to break other stuff.
I have the BK054 Lockout KitIs it possible the stock bushing allow for enough flex that it helped contribute to the failure? Curious if stiffer/solid bushing would help prevent this.
You could be right, or you could be wrong.My feeling is the lockouts are the reason they failed. The iron housing should be fine, but the forces have to go somewhere and the bushing's ability to absorb that energy is quite compromised. This isn't a knock on your products at all...just the harsh reality of the mechanics and physics of the systems.
I am a mechanical engineer who has been working in the automotive industry, at OEMs
Indeed, that has some merit. Even so, the bushing will absorb energy as the diff bolt travels through it, even if it does bottom out, it's still hitting some bushing (the outer material). It really depends on whether or not the diff housing continues to accelerate as it works the bushings, or if the force input is just an impulse from initial loading. Sounds like it could be the former.You could be right, or you could be wrong.
The issue with your theory is, you would need to test whether the "shock" to the ears is more when being solidified (not giving) OR when they bottom out of their cushioned travel after the initial hit. Many times, if you allow something to move - then it bottoms out, that harsh stop of movement can be worse than the elimination of the movement altogether.
To provide more data, I have had a customer actually shear the diff bolts.
So, it is of your opinion that the diff housing shears before the 14mm bolts do? If so, that is not very "good" IMO.
FRPP offers billet aluminum diff bushings for the S550 IRS system. The Ford components are tested rigorously before being released to the public. I am very curious to know if they tested them out on an aluminum diff, making bigger power. I do not think they did, but I could be wrong.
Somehow, some way, the aluminum version was proven inferior at Ford. The proof is that they put the cast iron in all of the manual trans cars, that make 435HP.
Yikes!Scary stuff...
Because the previous passes were made with much less power, and no BK054 kit. lol
Time will tell. I predict many failures of many different parts out back in the next year or so. People are finally getting these cars figured out, and there were some very fast ones at the event over the weekend.
