Niz55
After installing my sport lines I noticed a clunk when I hit a pothole or bump. It was coming from under the car. I thought my sway bar endlinks were lose but I double checked and torqued them to spec 85lbs.
I got under the car and started to look around. What I found was the bottom end link stud is hitting the frame of the car. I have my front sway bar in the middle hole. I will be purchasing bmr endlinks end of the week and hopefully that will fix the issue. I can also cut the litter stud so it will clear the frame.
Here are some pictures,
Where is hitting
Half inch away from the frame while the suspension is loaded.
Where is hitting
