h65
- Nov 22, 2014
- Pacific NW
- Harry
- 1965 Fastback, 2015 GT Premium (CO)
I checked the pre-amp signals of my 400a system and found them to be in range of RCA line level. This is just confirming what we expected.
The range is 0.04 volts at 20% volume to 1.53 volts at 80% volume (and 3.1 volts at max volume) with a CD audio source.
I used a female Molex 34690-0160 plug to connect to the harness that feeds into the amp.
http://www.mouser.com/Search/ProductDetail.aspx?R=34690-0160
I took my measurements from the #7 and #8 pins, which represent the front left signal.
These voltages are on the weak side so I'll be using an Audio Control Matrix Plus up front to boost their strength before a cable run to the trunk area. It's going to take about a week for the Matrix Plus to get here. I'll let you know how it goes.
In the mean time I'm feeding my system by summing the factory amp signals. Here are my components:
Front speakers: Focal PS 165 F3
Rear deck: Focal PC 165
Sub: JBL CS-110LGTW
Amp: Alpine PDX V9
DSP: Audio Control DQ-61
The DQ-61 is adding some hiss at low volumes. I'll be eliminating it from the system along with the factory amp. I think I'll want another DSP or at least an equalizer to replace it, but I'll tackle that after I hear whether I get a clean sound from the Matrix Plus.
Sub: JBL CS-110LGTW
Amp: Alpine PDX V9
