Toowired
- Dec 26, 2014
- West Jordan Ut.
- Ryan
- 2015 GT
This is Steeda's brand new IRS Bushing Support System.
Installation takes about an hour and can be done with the wheels on the car.
I would recommend taking the wheels off because it makes it easier to access everything.
Items needed
21 MM socket
13 MM socket
Impact or ratchet
5/32 allen wrench
lubrication
pry bar.
Loosen the 13 MM bolts on both sides.
Loosen the front 21 MM bolts
Loosen the rear 21 MM bolts so the subframe comes down 1/4-1/2 inch.
Remove the front 21MM bolts.
The thicker spacers will be used here. aligned the tabs on the spacer with the indentations in the bushing.
Install the front 21 MM bolts and just snug them down.
Remove the rear 21 MM bolts
Install the thin spacers in the rear and line up the tabs just like you did on the front.
This is the support for the rear bottom bushing. The smaller piece goes to the inside of the vehicle and the groove needs to face upward.
Install the smaller support by lubing up the bushing and sliding it around from the side.
The small portion of the support is mostly in place. use a pry bar to make sure it is straight.
Slide the other part of the support in between the busing and align the ends.
Using the pry bar wiggle the support back and forth until you have both ends lined up perfect. Take your time doing this so that the bolts start easily.
Tighten your 13 MM bolts and your 21MM bolts on the front and rear and you are done.
Items needed
21 MM socket
13 MM socket
Impact or ratchet
5/32 allen wrench
lubrication
pry bar.
