I figured the gt350 front brakes were lighter with their chamfering system. I want it for the looks at weight reduc...do you have a recommended two piece? I saw a j-hook one awhile back but it was waaay too pricey.Fronts no point, GT's brakes are more than enough, all I would recommend is going to a two-piece disc up front to shed some pounds.
Be nice to get the Shelby rear braking system though, but then you need to make sure the brake bias would still be OK and not messed up.
Girodisk I believe.There is another slotted 2 piece rotor floating around the forums for about 500 a disc, I forgot the name though. They saved about 9 lbs or so if I remember correctly
The most cost effective upgrade is this, changing the rotor saves you the most weight and its direct unsprung weight so you don't only shed weight but your handling, ride comfort all improve due to the suspension being able to control moving mass better.Girodisk I believe.
No they will not work w/regular rotors, GT350 rear rotor is 15" regular cars are 13" and the surface area that the pads use are different too.
For anyone wondering about brake fitment, everything is different up front, the knuckle/hub, brake lines, backing plate and probably the control arms/balljoints too. The GT350 caliper mounts differently, the knuckle is aluminum and it uses a hub not a spindle.
The rears look like they might bolt up, the knuckles look similar, but the parking brake is completely different. It has a shoe in hat style set up, has different e-brake cables, backing plate, theres a new bracket and the hub might be different too.
Front GT PP Caliper
GT350 Front Caliper
Regular Rear Caliper/Parking Brake
GT350 Rear Caliper and Parking Brake
Regular Front Spindle
GT350 Front Knuckle
The Real Deal - forgot to grab some pics of the rear set-up, maybe the next one
Yes but they don't have rears to match and are ridiculously priced. Well semi justified but still pricey. And I haven't seen any replacement disks yet for it. So if you need new rotors you have to pay $1500 again?The GT PP calipers with the AP two piece discs are a winning combination!
New discs can be had for msrp at 800 dollars.Yes but they don't have rears to match and are ridiculously priced. Well semi justified but still pricey. And I haven't seen any replacement disks yet for it. So if you need new rotors you have to pay $1500 again?
