Xantom
Road debris getting thrown into your rear quarter panels. Premature bearing wear.Are there any downsides to spacers? I'd like to widen the stance on my '15 GT 50th appearance wheels too.
Got anything to back up this claim or did you hear it on the interwebs?Premature bearing wear.
When I was doing research on them, before I bought mine, I can remember numerous people mentioned that you will get premature bearing wear. How much wear and how soon you will notice it, I have no idea ¯\_(ツ)_/¯ Here is a video of someone explaining some of the dynamics of wheel spacers. Go to the 5:00 mark for the bit about how spacers affect your bearings. It makes sense to me, but I am not an engineer, and this is the first set of spacers I have ever used. My car is in my garage 99% of the time, and not my DD. For me it was an acceptable risk until I find a set of wheels that look good and aren't $2000 a wheel. So yes I did hear it on the interwebsGot anything to back up this claim or did you hear it on the interwebs?
The guy in the video makes some interesting points. But, by his theory, it seems that a wheel with any offset could do the same thing. I am not sure I can buy into the theory that a slight offset will do much damage to my bearings under normal use.When I was doing research on them, before I bought mine, I can remember numerous people mentioned that you will get premature bearing wear. How much wear and how soon you will notice it, I have no idea ¯\_(ツ)_/¯ Here is a video of someone explaining some of the dynamics of wheel spacers. Go to the 5:00 mark for the bit about how spacers affect your bearings. It makes sense to me, but I am not an engineer, and this is the first set of spacers I have ever used. My car is in my garage 99% of the time, and not my DD. For me it was an acceptable risk until I find a set of wheels that look good and aren't $2000 a wheel. So yes I did hear it on the interwebs
Damn that video was hard to watch!!! :headbonk: I agree it's an acceptable risk. I have been owned and been around Mustangs longer than I want to admit and have never seen a bearing failure due to wheel spacers or wheel offset changes. I have the 1" Coyote spacers on the way with no worries.:cheers:When I was doing research on them, before I bought mine, I can remember numerous people mentioned that you will get premature bearing wear. How much wear and how soon you will notice it, I have no idea ¯\_(ツ)_/¯ Here is a video of someone explaining some of the dynamics of wheel spacers. Go to the 5:00 mark for the bit about how spacers affect your bearings. It makes sense to me, but I am not an engineer, and this is the first set of spacers I have ever used. My car is in my garage 99% of the time, and not my DD. For me it was an acceptable risk until I find a set of wheels that look good and aren't $2000 a wheel. So yes I did hear it on the interwebs]
^^^^^^^^^^^^^^^^^^^^^^^^^All good points on the risks but I'm going to make the assumption that Ford engineers built into the bearing load rating the ability of an aftermarket wheel or spacer moving the wheels out to the edge of the fenders ... so about an inch.
Having said that, if I was tracking my car, I'd play it safe and take the spacers off. And not because I don't believe the bearings couldn't take it but because of the severe stress it'd put on the spacer lugs, which are not OEM.
My car's a weekend toy and not a DD so minor risk accepted as well!
Agreed! 20 MM Eibach spacers here on PP wheels. I put lug nuts on the wheel studs first, measured and using a cutoff wheel, removed about 6mm off front and back wheels studs. I checked, then double checked to make sure clearance was good between pocket in the wheel and exposed stud. Cleaned them up with a file, then removed the lugs to further clean them up and painted the exposed end of the stud. When I installed spacers the lugs went right on without a problem. Personally, I think the 20 mm spacers are perfect. I didn't want any of the tire to extend beyond top fender lip. I also recommend swapping out the chrome lugs for Black Gorilla lugs, just because they look much better on the PP wheels..If you have to cut the lugs, maybe you could put a die on the lug, cut it then turn the die back off it? I've heard people doing that with an open end lug nut.
Either way, best of luck. Sad you can't drive it for so long.
You might be the one I was thinking of if you posted about that when you did it. I remember reading that. That sounds awesome and I agree 100% on the fitment. That extra 1/4" (5mm) would be perfect to set the tire just back far enough and still be aggressive.Agreed! 20 MM Eibach spacers here on PP wheels. I put lug nuts on the wheel studs first, measured and using a cutoff wheel, removed about 6mm off front and back wheels studs. I checked, then double checked to make sure clearance was good between pocket in the wheel and exposed stud. Cleaned them up with a file, then removed the lugs to further clean them up and painted the exposed end of the stud. When I installed spacers the lugs went right on without a problem. Personally, I think the 20 mm spacers are perfect. I didn't want any of the tire to extend beyond top fender lip. I also recommend swapping out the chrome lugs for Black Gorilla lugs, just because they look much better on the PP wheels..
Great info and validation. Just a heads up, you're torquing the wheels to the adapters too much. Read the chart on the side of the Coyote box. You should only be torquing the wheels to about 95 lb ft. Be careful or you'll strip those adapters.So I recently bought the Coyote brand 4x25 mm spacers from American Muscle and with some mild'ish weather, finally got around to putting them on and taking some measurements.
The 25mm on the front where perfect but with the Pirelli's bulge they stuck out past the fender too much for my liking. I'd heard that 23mm was as small as you'd want to go in the rear. I did some measurements and that seemed to be the case but I thought I'd get the rear set milled down to 22mm. I figured I could always grind the top of the wheel studs 1 mm if I had too.
So I took my 2 rear spacers off and brought them to a machinist I know and he milled them down to 22mm for me. He had to press out the splined studs from the spacers to get the spacer on the lathe but that was a breeze. When they were done being lathed down, he pressed the studs back in and home I went to give it a go.
I cleaned the face of the hub with some 100 grit sandpaper and likewise the back of the rear wheels. I put a thin layer of anti-seize on the back of the spacers and on they went on 1 side for a test fit. Torqued the spacers to 120 ft-lbs and then the wheel onto the spacer at 150. Took the wheel off then to see what the pockets on the back of the wheel looked like and you can see the stud's left a mark on them so 23mm seems ideal IF you don't want to cut the stud or do what I ended up doing below.
First pic is the spacer on the wheel with the stock silver studs sticking out a bit.
2nd pic is the back of the wheel after I removed it showing the marks left in the wheel pockets.
3rd pic is what I did to allow the studs to seat themselves into the pocket safely (I drilled a small pocket within the pocket).
I still think 20mm is the perfect stance for the back on the Pirellis. However, my next set of tires will have a less bulgy sidewall so who knows ... I'll spend more time looking at it and decide if I want to try 20mm but deepen the mini-pockets I made.
So, for those of you running 20mm on PP wheels you've likely pressed the stock studs out the back of the hub by 3mm ... not sure I'd worry about that as the nuts will keep them on nice and tight regardless.
Anyway, curious to see what you do with your 20mm Fordever.
