Enzo
Quick question if I just opt out for a single piece aluminum would alot of these issues just go away?
Sent from my SM-N920T using Tapatalk
I'm not so sure the drive shaft and pinion flange are a matched set. If they were, then everyone who had a new drive shaft ordered by the dealership should have also received a new pinion flange with the new drive shaft. I don't recall reading that ever happened.D) Replacing the driveshaft alone almost never works (See B above - DS and flange are supposed to be a matched set).
Sorry - I should have clarified earlier. They are "supposed" to be a matched set in order to rotate smoothly. What is obviously not happening is the "matching".I'm not so sure the drive shaft and pinion flange are a matched set. If they were, then everyone who had a new drive shaft ordered by the dealership should have also received a new pinion flange with the new drive shaft. I don't recall reading that ever happened.
I would think the flange is balanced by itself, as is the drive shaft so that those individual parts can be replaced without being a "matched set". The pinon flange has holes drilled in it from balancing, and has a yellow mark on it to show where a drive shaft yellow mark should line up. Not sure if the yellow mark is the heavy or light spot.
Sounds like you've got it. The denial stems from a mismatch of parts and no solution yet for how to address it.I am very thankful I found this thread. I bought my 2016 GT about two weeks ago and it now has 850 miles. I felt the vibration almost immediately but I thought it was just because I have been driving a suburban for the past 15 years - I thought I just had to get used to driving a car. But after I drove to Tucson (120mi) a week ago, I realized that maybe there was something wrong. That's when I started searching the internet and found this thread as well a several others.
I am taking the car in tomorrow am and I plan on taking this thread with me. I'm anxious as to what I'm going to face with the dealership - sounds like it could be anything from denial to a quick diagnosis and expedient fix. Very nervous!
I guess I have a question about how severe the vibration is for others. The vibe that I'm feeling isn't huge, it's almost like a vibration from cranking the bass on your stereo - just not thumping, but constant between 50-70mph. Is that what others are experiencing or is it more severe. I'd hate to be complaining about a problem that really isn't that severe. It is VERY annoying though.
I will post tomorrow once I hear something from the dealership.
That's kind of where I was I thinking as well. I have a perfectly good beater truck to commute in, and the wait gave me an excuse to address a couple issues and upgrades with it.Order a 17. When I won my arbitration on a 15 EcoBoost and Ford couldn't locate a 15 GT with options I wanted I Special Ordered on 16. Why the hell do you want another 15? At least get a 16.
Sent from my iPhone 6s Plus using Tapatalk
It had the vibration on the test drive (May 2015), and I took it in at 1000 miles. Like many others -- and like most vehicles -- I assumed it was a tire.Jim, when did you take delivery of your '15? How long did you have it before it went in the shop?
Congrats that they decided to replace it. If they have to buy back a few lemons due to this issue I would think that addressing it would be a very high priority.
Steering wheel shake is not driveline related...
the excuse is "we dont have a TSB or a clear path to fix this, we dont want to work on it, we're ford techs. what do you think this is, a (insert Lexus/Mercedes/Infiniti/Acura/Honda/Toyota) dealership"Maybe. But it's also not normal. And NOT from my Roush exhaust. So dunno what their excuse is for "can't find anything wrong"
Lol funny you mention that. That's the biggest factor for a lot of return customers and also quality control.the excuse is "we dont have a TSB or a clear path to fix this, we dont want to work on it, we're ford techs. what do you think this is, a (insert Lexus/Mercedes/Infiniti/Acura/Honda/Toyota) dealership"
