Stuck on Manifold choice Sniper vs. 302
West TX GT
Ian
2018 Royal Crimson GT
Just curious why the Cobra jet wasn't in the running. Wouldn't it outperform both of these, and if you have to cut the hood anyway? I ask because I am planning on running a high revving Cobra jet N/A setup for a bit before throwing a centri on there. Should I be changing my plans? Is there something I'm missing?
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
Dual throttle body and the gains over Boss 302 were not enough to justify ~$1000 more. for that I can buy and e85 kit or turn my boost up a .5psi.
Question:
I have a strong fuel smell after install...I noticed i have 2 injectors on the passenger side that are wet..Do the ID 1000's need a spacer with stock fuel rails and the Boss [MENTION=10926]beefcake[/MENTION] do you know? or do I need to re-seat the injectors?
beefcake
Bethel
2018 Ford Mustang
Question:
on an n/a car, should have a spacer on the top and bottom, we always lube the o ring gaskets
beefcake
Bethel
2018 Ford Mustang
FYI, we have gt350s in stock again
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
beefcake
Bethel
2018 Ford Mustang
What about a boosted car?
depends on the blower,
on a paxton, procharger will be the same
whipple kits come with their own rail setup and are shorter
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
In my case I have a PC and no spacers currently in same as I had on the stock intake manifold.
beefcake
Bethel
2018 Ford Mustang
they will be the same height as the stock injectors,
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
Anyone know where I can get the top O-Ring for an ID1000
Found my issue
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
Nevermind I just found out T1 Race/Injector Dynamics is about 30 minutes away...off i go!
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
anyone know if the stock top o-ring is ok to use on the ID1000? seems like they are the same size
Tommy V
Brookly park Md
Tommy
U can use the stock size,just an fyi,i usually put just a drop of oil on the oring to keep it from tearing or twisting.
15GTPP
El Paso
2019 GT
For those of you that want to clean up the hole that you had to cut in the hood, get 5/32 vacuum hose and split it open and slide it over. You can glue if you need to but mine is staying without any glue. I used about two feet and it looks really clean now.
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
I ended up buying black pinch molding from autozone for like $5 and it looks pretty good. Unless you are looking for it it is hardly noticeable.
