SolarFlare
Shows it as available hereSo let's say I split the difference and close the wastegate and run pulley only. The middle ground from 4.75 to 4.38 is the 4.5 pulley correct? I do not belive you make a 4.63 in 8 rib. So if the max impeller speed is 60799 at 7700 rpm, do you know what amount of Boost that would be at 750ft above sea level? (Dallas). I want to stay below 12.5. Gracias [MENTION=11041]ProChargerTECH[/MENTION] !
http://www.jpcracing.com/procharger-8-rib-supercharger-pulleys/
