Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
The shortest answer is, it's an even value. It's incredibly expensive, but incredibly great. Or said the other way, it's AWESOME, but it's EXPENSIVE.Side curiosity question, how do you like the MOTEC M150? Did you mainly get it for better torque management during launch/traction control?
Has it been worth it for you personally?
Part of the huge cost is the proprietary harness they create specifically for your application. It's enough to make you fall out of your chair. But I was "told" that there's no way everything will work properly if you don't go through them to do the jumper.
The rest of it, my only complaint is that I'm having issues with my power steering and we're trying to solve why it's heavy now.
But the rest is pretty remarkable.
True flex fuel on a high output PD setup (small pulley). Full control over things like flex fuel sensor input, MAP, fuel pressure sensor, PWM controlled pumps, even things like the intercooler pump control (I have an interchiller system), etc. It has not only wild controls over torque output (by gear and rpm), a "3 stage" launch control, but incredible engine protections and fail safes as well (things like oil pressure drops, fuel pressure drops, AFR spikes, etc).
I'm curious as to how close PCMtech is going to be able to get with all the functionality. It seems that they're able to achieve the same level of flex fuel capability, however, I haven't seen (doesn't mean it isn't capable) the same level of sophistication with respect to custom mapping of the torque (by gear). Not only is the MOTEC approach MUCH more proactive in managing traction (you can pre-limit how much torque the car is capable of making at given rpm in a given gear) but it also monitor wheel slip "aims" that you can set how much you want (right now the various "levels" are 1 mph wheel slip up to 10 mph but I can adjust those to my liking or just select from that menu).
There are a couple of drawbacks. You lose your OE computer. Which means no more adjustments via FORSCAN. I think there are SOME adjustments that can be made in the M1Tune but many of them are rolled up into MOTEC's firmware for the specific vehicle. And I'm pretty sure adjusting any of those is practically out. What does that mean? It means if you have a custom FORSCAN build for anything like lights or chimes or alarms or stereo stuff, that's all reverted back to what it was stock. I also lose the ability to run my Ngauge as a nice 6 sensor gauge monitor (but MOTEC is doing all that for me now).
In short, it's like "You'll win the lottery, but you have to lose one of your arms or legs."
