Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
The Dodge's were locked from the challenger unveiling. You can get a jail broken PCM and tune it that way, but you absolutely void the warranty as there's other systems that will recognize and store codes concerning the conflict. So your choices aren't exactly great, send off your PCM to be permanently modified or buy a separate broken PCM and do the install, either way, your warranty is definitely gone out the window. (not that this is a huge consideration admittedly).I've seen you say Dodge a few times. Which Dodges can't be tuned?
Technically they didn't crack it, they simply wipe the OS and install a replacement for you on your PCM that's open and available for manipulation.
NOT exactly the same as reflashing a S550 PCM and having the ability to reflash it back to stock later with the unit remaining in place in the car.
A more nuanced aspect would be if you're simply wanting to update a tune for a mild build, you have to go through the headache and expense of a broken PCM.
