Bluemustang
I admit I am a bit confused myself. I do have some Koni dampers in my garage and BMR SP080 springs. I could pickup a BMR SP089 front spring...I don't disagree with your methodology here, but I do disagree that the bearing causes binding. I have the stock vertical links (see zero reason to change them out), but everything else is bearings. With the sway bar disconnected and the spring/shock removed, the whole assembly moved from stop to stop buttery smooth. No binding at all whatsoever. My guess is that you will get the best results swapping out your struts/shocks with something different. The reading I've done on those Ford Performance shocks and struts is that they are only incrementally above the stock PP struts and shocks, which are woefully underdamped. :shrug:
I find it hard to believe others with the FRPP track pack haven't run into these issues that I'm having and that led me to believe that the bearings may be not meshing well with the overall setup.
The Ford Racing shocks, they do feel underdamped to me though.
