Question on re-using caliper mounting bolts.
Ewheels
SoCal
Eric
2018 GT PP1, 2020 Explorer, 2023 F150
The caliper bolts are not torque-to-yield bolts. They say "one time use" because of the loctite they come with. You can 100% reuse them.
If you remove your calipers often, do not reapply the loctite. The frequent removal and reinstall with loctite will gall the threads and could damage them. If you rarely remove your calipers, then continue to reapply loctite
boB
boB
2019 GT PP1
All decent bolts have rolled threads which are superior to cut threads. Because of this I would not use a die on any bolt that is holding together anything important.
Veteran
Italy
2020 GT white
Personally I think it’s all about liability.
Any Large corporation has a warehouse full of lawyers covering their arses.
Veteran
Italy
2020 GT white
Fwiw, I remove caliper bolts on my 1000cc race bike at each tire swop. Caliper must come off to remove rim.
Make that at least 15 removals at minimum in a season.
that excludes pads and maintenance like suspension etc.
make that another 6 times a year.
so round out 20 times a year, and I have been at it for a few years.
All on the same caliper bolts !
But to each his own…..
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
In my 60 + years of traveling around the sun I have never changed a caliper bolt. I have never used a thread locker. I have never had one come loose.
I do properly torque them.
pyrophilus
pyrophilus
Westchester, NY
'19 ShadowBlack GT Premium401a, PP1, ActiveExhaust
GM was "helpful" enough to use torque-yield bolts on the Camaro calipers so they are a literal once and done. Ford was much smarter in this regard. Use a wire-wheel or a pick. Ideally you'd have tap and die set but it's not a biggie.
I'm not so sure I would do brakes/hub right before a long road trip though.
Not leaving right after, but I think I will be fine as I have done this before, just not on a mustang.
I usually do brakes and them drive bait, then next day double check everything.
Albeit it's been awhile since I've done hub bearings, last being on my '92 maxima back in '98.
pyrophilus
pyrophilus
Westchester, NY
Same here. I have been doing little things like brake pads, discs, and CV joints on my older cars, just not on mustangs.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
I've never replaced a caliper bolt that I didn't have the decency to shear off first. I've also never used thread locker on one and I don't think I've even used a torque wrench on one yet I've managed to avoid flying off the highway in a flaming wreck so far.
K4fxd
NKY
When I worked as a line mechanic I would run them tight with the air ratchet then give another 1/8th turn. On my race cars I used a torque wrench.
shogun32
Northern VA
so customer cars got the slap-dash tosser treatment but when it was your own life on the line you used the proper tool?
bnightstar
Bulgaria
Hristofor
2013 Ford Fiesta 1.25i, 2017 GB Ford Mustang GT PP Premium
Replaced a lot of wheel hubs first time I hear about that I have to replace bolts on break callipers with it. Track my car no problems.
