A tune can't produce the same effect the pedal commander or similar product provides. While a tune can make for example 20% throttle feel like 30% throttle (similar to how Sport mode in an automatic car does), a tune can't get you to 20% throttle quicker. This is what the pedal commander helps with. You'll get off the line quicker, you'll get to WOT quicker from any pedal position. The effect has to be experienced to be appreciated. I've had local, Lund, JDM, & Steeda tune with tune revisions from some of them and after using first the pedalmax and now the pedal commander, the tunes alone feel seriously lacking. Drive by wire sucks that bad! If you want to save $300 then don't even try it, because I promise you, you will not want to drive your car without it once you've tried it.Is it a pedal commander worth $300? Does anyone have it and notice a big difference? If so would it be better just to get a tune?
http://www.americanmuscle.com/pedal-commander-throttle-controller-1117.html
It speeds up electricity. ;)A tune can't produce the same effect the pedal commander or similar product provides. While a tune can make for example 20% throttle feel like 30% throttle (similar to how Sport mode in an automatic car does), a tune can't get you to 20% throttle quicker. This is what the pedal commander helps with. You'll get off the line quicker, you'll get to WOT quicker from any pedal position. The effect has to be experienced to be appreciated. I've had local, Lund, JDM, & Steeda tune with tune revisions from some of them and after using first the pedalmax and now the pedal commander, the tunes alone feel seriously lacking. Drive by wire sucks that bad! If you want to save $300 then don't even try it, because I promise you, you will not want to drive your car without it once you've tried it.
I ended up getting the FPP2, and I am liking it so far.A tune can't produce the same effect the pedal commander or similar product provides. While a tune can make for example 20% throttle feel like 30% throttle (similar to how Sport mode in an automatic car does), a tune can't get you to 20% throttle quicker. This is what the pedal commander helps with. You'll get off the line quicker, you'll get to WOT quicker from any pedal position. The effect has to be experienced to be appreciated. I've had local, Lund, JDM, & Steeda tune with tune revisions from some of them and after using first the pedalmax and now the pedal commander, the tunes alone feel seriously lacking. Drive by wire sucks that bad! If you want to save $300 then don't even try it, because I promise you, you will not want to drive your car without it once you've tried it.
:lol::lol:It speeds up electricity. ;)
So you are saying there is a chance of getting to Warp 5?It speeds up electricity. ;)
And they can charge you $300 for it and you'll be reasonably satisfied. How 'bout that. f'ing geniuses!It speeds up electricity. ;)
That's not what it does. A lot of people think it's wider throttle opening per pedal input, but it increases the rate of the peddle press. If you measure pedal press in real time, it's faster. For automatics especially, it's night and day difference in "throttle" response. It makes normal driving (you know when you're not rev'ing it to 4k-5k rpm) faster, smoother, and as a result more enjoyable. And when you want to get on it, you're still faster than the same car and driver with the same exact build (minus the device) because you have the faster trigger.:lol::lol:
Love how people think this does anything but change the input/output signal ratio. Just put your foot down harder, more.
Yes i have both and love it.Can you use this in tandem with Ford's pp2 tune?
I'm not going to disagree with your preference on how much effort you like to exert on the pedal, but a tune cannot produce what these devices do. The nice feature of the pedal commander is you can drive it with it completely turned off or at varying levels including a level that is way too touchy for normal driving.You just restated exactly what I said. The slope of the pedal output to input curve is higher, which makes it "respond faster" and simultaneously command more throttle for a given input. There's no speeding up the throttle body. The only way to do that is to increase the voltage to it, and this isn't doing that.
I get why auto guys might like this, but honestly I've never felt any significant throttle lag to input in the 2.5 years of ownership. I actually had my tuner tone down their driver demand because it was too touchy at low throttle and would command far too much, making normal driving more challenging than necessary.
The Lund tunes that I tried did have a "lighter" feel (much like in Sport Mode), but again what is done in a tune is not the same experience. However good you think the tune is, add the device and it feels so much better. If you want improved throttle response (even on top of your very responsive one) then these devices help with that.I've never tried the Pedal Commander device so I can't comment on what it does or if it works. I can tell you that I noticed the throttle lag on the stock tune and even on my Bama tune that I had before. Now with a Lund tune I do not feel any throttle lag. It might still exist but if it does I cannot notice it anymore. The gas pedal feels "softer" with the Lund tune? Spongier? Point is very responsive. If anything it can be almost too responsive at times. Therefore, personally I do not see a use for this device. If I put my foot down it goes almost instantaneously.
I agree. Plus I can change the pedal feel for when the wife drives it!The Lund tunes that I tried did have a "lighter" feel (much like in Sport Mode), but again what is done in a tune is not the same experience. However good you think the tune is, add the device and it feels so much better. If you want improved throttle response (even on top of your very responsive one) then these devices help with that.
