Mid_life_crisis
- Sep 4, 2016
- Raleigh, NC
- 2016 ecoboost premium
Silly is pretending you aren't fully aware that most people hear "electronic crossover" and picture active devices. The kind that are complex circuitry that requires a power supply. As opposed to simple components.A fixed xover frequency is true of any crossover, whether passive or active. And both types are electronic. Active xovers are powered, connected pre-amplification, and usually have some form of manual adjustability. To suggest passive xovers are not electronic is silly. They're certainly not mechanical. ;)
Subsonic filtering is a high-pass filter, not a crossover, though the frequency at which the filtering occurs is also fixed. Contour deals specifically with EQ. Yes, increasing the volume level affects contour (by design); however, it is not so with crossovers or high-pass filters, both of which are NOT designed to vary due to changes in gain. It would create all sorts of problems. Contour is an interesting point, though. I suspect what OEMRadio perceives as a change in xover is really a change in the acoustical crossover (not to be confused with the electrical crossover, whether passive or active).
You can't get crossover values from an active crossover that is set up via programming, as opposed to switches and/or dials.LOL. It's not difficult to obtain that info based on the values of the components. What do you mean by experimental method?
Experimental method is just what it sounds like. Supplying a known variable frequency to the system and measuring what comes out of each speaker; experimenting.
