It seems like a lot of people don’t understand tire and rim relationships.
Dinokill3.7
2017 Mustang Gt PP
More often than not, I see people recommending getting wider tires when someone ask for fitment and/or grip recommendations.
Getting just wider tires while not changing the rim’s width won’t do much
for example, I saw a guy that had 325 tires on a stock 9.5 inch PP rim.
The contact patch will pretty much be the same if you get wider tires and leave the rims alone.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Yep plus you run into safety issue, tire could pop out in sharp turn in addition the car gets really floaty when side wall bulges out like that.
Bluemustang
2015 Mustang Base GT
The contact patch will pretty much stay the same regardless. Only the shape changes. It's based on mass and tire pressure. If you go wider, you need to decrease pressure to widen the contact patch.
HKusp
Hampton, Md.
Jason
You can sum a lot of things up with; "People are stupid." It applies in many situations.
Bobby57
Port St. Lucie, FL
Bob
2016 Mustang GT Premium Convertible
This is a great reference : https://www.wheel-size.com/calc/
Rim
width
(inch)
Min.
tire
width
(mm)
Ideal
tire
width
(mm)
Max.
tire
width
(mm)
5,0155165 or 175185
5,5165175 or 185195
6,0175185 or 195205
6,5185195 or 205215
7,0195205 or 215225
7,5205215 or 225235
8,0215225 or 235245
8,5225235 or 245255
9,0235245 or 255265
9,5245255 or 265275
10,0255265 or 275285
10,5265275 or 285295
11,0275285 or 295305
11,5285295 or 305315
12,0295305 or 315325
12,5305315 or 325335
ing3nious
New Jerz
Mom mobile
Hmmm 10.5” with a max of 295. Guess the ford engineers didn’t get the memo or threw it out for the PP2 or Mach1.
MLO 351
Australia
Pete
2021 Mach 1
From what I've read, tread width is the key metric, ideally tyres that are 1/2 an inch under the rim width, provides for the best handling option with up to 1/2 an inch over rim width being acceptable.
shogun32
Northern VA
Ford was going for style points and bragging in literature. That said 305 does fit and survives heavy track use.
In all matters of engineering except bridge building there are fudge factors.
Plus a 295 tire isn't remotely 295 across. That is why tirerack measures every damn tire using a consistent methodology.
HKusp
Hampton, Md.
Jason
50% are stupid and the other 50% don't know it .
The 50% that don't know it are the REALLY dangerous ones. Seems like a lot of them go into politics.
Bob Lob Law
Jeff
'22 GT Premium
Tires are also allowed up to a 10% difference in actual size compared to indicated size. Some manufacturers are more true to size than others.
WItoTX
Houston
Kyle
'17 GT350
Ford designs the car to meet a whole host of requirements, not solely performance. More sidewall = more comfortable ride. Because most people buying mustangs will only drive them to and from work.
