Help! Empty gas tank without running it.
TexasGT
Derek
2016 GT
So, I have an indoor car show this weekend. I wasn't aware that you can only have a 1/4 tank. Got the car professionally detailed today for the show. Now, I need to pull out about 8 gallons of gas... how does one do this?!? I managed to get a hose in and pushed to bottom, and didn't even touch gas.
Help!!!!
keltymd
Murfreesboro
2017 PP
let it idle for a LOOOONNNNNNGGGG time or disconnect the fuel line at the fuel rail and manually run the pump
TexasGT
Derek
2016 GT
Beyond my experience unless someone gave me some instructions! I mean the fuel rail part :)
TexasGT
Derek
2016 GT
Can't bro! Just dropped $200 on full detail!!
TruBlue16
Central Florida
2016 DIB Mustang GT w/PP
:D
[ame]
Tejas
2016 GT PP
Disconnect fuel line, attach hose to end, run other end to buckets, pull starter fuse, "crank" until tank is empty.
Dunno of that will work but seems like it will
TexasGT
Derek
2016 GT
Siphon? Stick a hose in the gas tank like you're stealing it.
If only it were that easy!!!! Been trying for an hour and that just doesn't work.
cbrookre
Ridgefield, WA
2015 Mustang GT Convertible 50th app
The fail-proof method
[ame]
TexArmageddon
Dallas
Corvette
Simple either disconnect the Fuel line and pump out that way, leave the car running, or dump the tank... those are your only options if you aren't trying to drive it...
Or you can just jack up the car and floor it..
Ground Speed
'16 White EB+PP
I'd say go for a long drive and then do detailing touch ups when you get back (and once the engine has cooled back down.)
HISSMAN
Large Member
West Virginia
Use the special funnel that is in the trunk.
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
Just go to the car show with the full tank. Most likely nobody is going to check your fuel levels
