Yes, check to make sure if "auto" is switched on. If auto it on, you can't change fan speed until you press it to turn it off.Did you try taking it off "automatic"? Then try to adjust fan speed. Not sure if that is the problem, but if it is hot in the car, the fan speed will be high till it cools down if it is in "auto" mode.
My wife refuses to learn, or try to understand how "auto" mode works. So when she drives the car, she turns the temperature all the way down to cool the car, then when it gets too cold, she turns it off. So frustrating. I try to explain that in "auto", all she needs to do is set the temp where she likes it and forget it. Then she can just make adjustments by kicking it up or down a degree or so as needed. But she just doesn't get it.
you could have auto on, or max AC or max defrostI noticed today that adjusting my fan speed has no affect. The fan constantly stays on high no matter what, unless off.
Anyone else notice this?
Guess it will be back to the service lane.......again.
Not true! I use auto all the time and I can still adjust the fan speed!Yes, check to make sure if "auto" is switched on. If auto it on, you can't change fan speed until you press it to turn it off.
I should say if auto and max a/c is on, then I can, but if just auto is on then I can't. Maybe something else was on that I did not notice, but I do remember not being able to turn down the fan speed until I turned auto off.Not true! I use auto all the time and I can still adjust the fan speed!
Yep, this is the way it should behave. As if you adjust the fan speed, things are now manually being operated.Auto light turns off in mine when I adjust fan speed.
Oh, thank god! I was afraid MY wife was the only Climate Control idiot in the world! I get so FREAKING TIRED of max cold until she is too cold, then heat until she is too hot, and then AC again....My wife refuses to learn, or try to understand how "auto" mode works. So when she drives the car, she turns the temperature all the way down to cool the car, then when it gets too cold, she turns it off. So frustrating. I try to explain that in "auto", all she needs to do is set the temp where she likes it and forget it. Then she can just make adjustments by kicking it up or down a degree or so as needed. But she just doesn't get it.
thisyou could have auto on, or max AC or max defrost
