HeelToeHero
I know but OP didn't have photos.^^^ Looks like it's leaking between the block and the oil cooler assembly. See post #26.
Thanks I'll look for the line when I follow up. I didn't see any oil trail from the sensor but there was oil on the block below it.I know this thread is 5 years old but for the new posts asking, check the oil pressure sensor just above the filter. I’ve seen several back out a bit and create this exact issue. The oil pressure sensor is marked with a white line indicator that will show if it’s backed out at all.
Your photos look like the leak source is behind the oil cooler and it's running down the bottom slope of the cooler housing. If it was just coming from the filter gasket the oil wouldn't be all the way up that bottom slope.I know but OP didn't have photos.
Hey HeelToeHero, I took it into my local ford service shop and they fixed it for free. It took a week but all good. Turns out it was a faulty adapter.Hey 2morrow my 17 looks just like this, what was your resolution?
I agree.Your photos look like the leak source is behind the oil cooler and it's running down the bottom slope of the cooler housing. If it was just coming from the filter gasket the oil wouldn't be all the way up that bottom slope.
Now that you've cleaned it up, go drive it a little (or just let it idle until fully hot might do it) and inspect again. If the whole bottom slope is oily again it would confirm its coming from behind the cooler.
Happy to hear you seemed to have found the source and that it’s nothing serious. Dealer will likely remove sensor, apply thread sealant or something, torque to spec, and call it good. Easy fixUpdate. 99% sure it's the pressure sensor. Will bring it to the dealer for documentation and resolution. Thanks a lot for the help.
Very common issue across all S550 platforms… Many have had this very issue where the sensor is loose and was not screwed in enough during assembly, and engine vibes make it loose.Update. 99% sure it's the pressure sensor. Will bring it to the dealer for documentation and resolution. Thanks a lot for the help.
