embraceentropy
- Sep 3, 2015
- Georgia, USA
- Chris
- 2019 GT350
So, I am having a similar issue. I changed my oil this past weekend using the MC filter. After starting it and letting it idle, I crawled back under and noticed a small drop of oil about to fall off the filter. I thought it must have been from the oil that was around the bore when I primed the filter. I roughly wiped off the filter and went along with my day. After reading this post, I crawled back under my car this afternoon to double check and behold there was a drop in the cover and drop about to fall off the filter. This was after about 10 miles of driving since the oil change. I noticed a film of oil right around the seal at the low point of the filter's circumference and thoroughly wiped everything down. I let it idle for about 5 minutes while watching it and I didn't see anything trying to come out.
The issue is that I have to make a 6 hour round trip (mostly highway) tomorrow in this car and I don't have any time to drive the car around and re-check the leak in the meantime. Thoughts?
Also, I'm second guessing how much I tightened the filter even though I'm pretty sure I went 1/2 turn after handtight. Is there any harm in just crawling under there and tightening it about a 1/4 turn or so without backing it off? Should it be done cold or hot?
