- Nov 2, 2015
- SE Michigan
- Scott
- Carroll Shelbys Soul Lives Under My GT350 Hood
- Banned
- #61
Those are not equal length and those are mid length.
whats the difference? not trying to be annoying just want to be educated, pics would be good to see the differenceThose are not equal length and those are mid length.
Equal length are when the primary tubes are equal length. Each tube from the head port flange to the collector is equal. The problem is this design takes up space and the S550 mustang doesn't have that space. Equal length is also a tuned header because each port and primary flow the same distance. The pictures of the Kooks headers you pictured are step headers. The primary tubes are of two different diameters. The smaller diameter primary is first, this helps with scavenging and velocity. Their are more to headers then tube diameters, lengths, collector length and diameters etc.whats the difference? not trying to be annoying just want to be educated, pics would be good to see the difference
The FPC voodoo will not be revised for one model year.I think it is foolish to think the 5.2 FPC engine will not see a horsepower increase in the near future. Ford has been known to leave some horsepower on the table when they introduce a new engine. I fully believe Ford will find a way to tune and revise intake and exhaust ports and change the intake design and etc, to bump horsepower to 580 for the 2019 GT350.
How far off of equal are the lengths? They look very close to equal to me, and if they aren't exactly equal, the lengths could surely be adjusted slightly. They also sure look like long tubes to me. I feel like you are splitting hairs here.Those are not equal length and those are mid length.
None of the tubes on that Kooks Gt350 header are of equal length. The front is the longest and they get shorter as they go towards the rear. Equal "tuned" length headers are of equal length. Not inches apart such as these. Primary tube lengths and diameters depend on engine size, rpm, hp, tq, weight, compression, etc.How far off of equal are the lengths? They look very close to equal to me, and if they aren't exactly equal, the lengths could surely be adjusted slightly. They also sure look like long tubes to me. I feel like you are splitting hairs here.
I respectfully disagree.Seeing as the '18MY GT350 isn't being revised, you'd assume that it'll only be around for this last model year.
Would they really leave it without changes for the '19 and '20MY before we then get the S650?
There's still the unanswered question of when the GT500 (or whatever it may be called) comes into the picture? Personally, I'd assume it'd be here for the '19 & '20MYs.
And what of the rumoured Mach 1? Will that ever happen? Will it sit between the GT and GT500? That pretty much where the GT350 sits now.
My thoughts.....if Ford aren't going to update Voodoo (and I'm not convinced they will) it would be good "marketing" to replace GT350 with the likes of the Mach 1 as a n/a 5.2 CPC V8 would, in my mind, slot nicely in place of Voodoo and it keeps Ford's promise that Voodoo would only ever be available in the GT350.
My ideal V8 scenario for the remain model years:
'18/'19/'20MY GT comes with DI/PI Coyote and 460hp
'18MY Bullitt 50th Anniversary based on the GT with DHG paint etc
'19/'20MY Mach 1 with 5.2 CPC and 525hp
'19/'20MY GT500 with a superchargerd 5.2 CPC and 725hp
:ford:
They made a Bullitt edition for the Sn95 New Edge and the S197.I respectfully disagree.
I don't see ford making another 50th anniversary bullitt. It was a one time movie stunt. Bullitt wasn't the only mustang movie and to keep the bullitt alive seems to be odd.
Building a Mach 1 5.2CPC with 525hp seem like an easy way out. Basically same as a GT350 minus the FPC and firing order.
My point is it's nothing special. It's not a 60s submodel.They made a Bullitt edition for the Sn95 New Edge and the S197.
So Ford has done it twice.
