Bit of disappointment at the dyno this morning...Whipple help me out?
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
So i spent the morning on the dyno this morning and ended up only making 592 at the wheels. I have headers and the 3.625 pulley and expected to make alot more? At 5k rpms on every pull my fuel went extremely An rich and I can't figure out why, this makes me believe I have alot of extra power to be put down. Any Ideas on why this is happening, Whipple feel free to step in here? I have attached a picture of the dyno sheet.
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
yup
sonic
NY
Prius
Are you running a boost a pump?
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Yes i am, I thought about that and unhooked it during the third run and it still did the exact same thing
sonic
NY
Prius
91 or 93? Im running out off ideas:doh:
sonic
NY
Prius
My guess is bad fuel and its pulling timing to be safe
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
I guess that could be it, there is no pinging what so every its 91 with octanium in the tank
Sheenapple
Houston
2019 Mustang GT PP2
check your KnockR and sparkadv. is there a datalog you can supply us here? maybe 10-20 rows of 100% pedal
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Have you called them or emailed them directly?
I have not yet, by no means am i blaming them, i was going to see if someone on here knew if maybe i overlooked something or maybe I did something wrong.
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
I don't think there is a way to data log with the whipple flare device yet? I could be wrong tho
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
10-4. I wasn't trying to be rude with my post:thumbsup:
Good luck getting it figured out. The Whipple setup is my favorite, BY FAR! I am jealous.
sonic
NY
Prius
I was told 3.625 I MUST be on 93 and no less plus run some sort off octane boost. That has to be your problem bro
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
You might be right, I figured since i had headers to lower boost and i am at almost 4000ft elevation i'd be ok running the octanium and 91, I was probably wrong. Hopefully whipple will chime in and set me straight.
