Anthony@FFtec
Vendor
- Nov 22, 2014
- Bay Area CA
- IS300
It's tax return season! Treat your car right!
For all you big turbo guys, and power junkies alike, read below!!
https://www.fftec.com/item/2070/4BAR_TMAP_Sensor.html
We are proud to announce the release of the most fantastic FFTEC Plug-N-Play 4Bar T-MAP sensor!*
This T-MAP sensor will precisely and accurately calculate boost pressure up to 4Bar(44PSI) while maintaining smooth OEM drivability!
The FFTEC Plug-N-Play 4Bar T-MAP sensor features on-chip temperature compensation which allows it to maintain an incredible 99% accuracy from 0°C to 85°C through-out its 0Bar to 4Bar range.
Pressure calculations are outputted on a full range, linear, zero to five volt scale. After proper sensor configuration and engine calibration (provided below), you will never need to re-calibrate your vehicle due to elevation changes again!
The FFTEC Plug-N-Play 4Bar T-MAP sensor uses a custom integrated on-chip, bipolar op amp circuitry, and thin film resistor networks to provide a high output signal and on-chip temperature compensation.
Being dimensionally identical to your OEM T-MAP sensor, including the connector, means that this is direct Plug-N Play for your Mustang Ecoboost while retaining OEM appearance. Install is super easy!
Features:
• Improved accuracy at high charge air temperature and increased boost
• Only 1.5% maximum error over 0°C to 85°C.
• On-chip processor is fully calibrated and compensated.
• On-board temperature compensation from -40°C to +125°C.
• Full sweep response time of just 1 millisecond
Benefits:
• Greater safety by retaining factory boost cut features at increased boost levels.
• Accurately control boost beyond the factory 28PSI sensor limit.
• 4Bar absolute pressure sensor allows for boost pressure up to 44psi to be
measured with greater accuracy.
• Allows for more accurate data collection helping to achieve the best calibration
results.
• No more need to re-calibrate your vehicle due to elevation changes.
• Plug-and-play installation. No need to cut into your vehicles engine harness!
Connector is the same as factory.
• Will work with the stock ECU or any aftermarket engine management system.
Proudly made in USA! The FFTEC Plug-N-Play 4Bar T-MAP sensors are assembled by hand, pressure tested, and function tested in the USA*for unrivalled quality control before shipping.*
COBB Calibration Data:
MAP Sensor Offset .0348 (bar)
MAP Sensor Scalar 0.8261 (bar)
For information or questions about calibration and use of this spectacular part, please contact our calibration staff by emailing [email protected] or [email protected]!
For ordering inquiries please contact us at [email protected]!
Click here to place an order today! >>>> https://www.fftec.com/item/2070/4BAR_TMAP_Sensor.html
We look forward to hearing from you!
Features:
Benefits:
results.
