WTB Cowl Extension Brace
Fuse
États-Unis d'Amérique
2016 Mustang V6
Hey if anyone is looking to sell their C brace PM me. I'm in Hudson County in New Jersey.
ctandc72
VA
'19 GT 6 speed Base
Are you looking for the smaller cowl brace or the larger 'k' brace?
I finally have everything on hand to do the K braces and smaller brace on my car. The smaller brace can be purchased brand new for @$50.
Fuse
Fuse
2016 Mustang V6
I'm looking for the brace that comes with the ford performance strut brace. The one that attaches to the firewall and then to the strut mounts. Maybe I'm not calling it right.
Do you have a link for the smaller brace, I'm not familiar with it.
ctandc72
VA
'19 GT 6 speed Base
Okay the brace that comes with the strut tower brace is usually referred to as the 'K' brace. It's the long brace goes strut tower to strut tower.
It is @ $100
FR3Z-16K038-A
https://www.fairwayfordparts.net/oem-parts/ford-cross-bar-fr3z16k038a
The smaller brace is usually called the cowl extension. It essentially ties to the larger K brace to the cowl of the car and replaces what is usually a plastic piece on non PP cars.
It is @ $50
FR3Z-63016A52-A
https://www.fairwayfordparts.net/oem-parts/ford-extension-panel-fr3z63016a52a
Check this thread out - it should help a lot
https://www.mustang6g.com/forums/showthread.php?t=100800
If you are installing on a V6 car - like I am...
You'll need 3 of these (you will remove several you already have which will be reused)
W717964-S450B Cowl Top Panel Bolt
And 4 of these (nylock nuts for where it bolts to the strut tower)
W712334-S440 Front Mount Retainer Nut
Fuse
Fuse
2016 Mustang V6
Yeah I'm looking for the K brace. Thanks for the link for the thread. I'm going to do the lower k-brace on my next oil change. I'll probably do the cowl extension eventually.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
$80 here instead. I see the other part called firewall extension more on here than cowl extension.
ctandc72
VA
'19 GT 6 speed Base
Installed the smaller extension and the K brace tonight. Already had the Steeda 2 point front brace and the Steeda IRS supports. This is worth EVERY penny. Tightens up the front considerably and smooths out transitions and bumps as well.
