Wtaf... any auto sparkies about?
Heretic404
Brisbane, Aus
Pete
2018 S550
Didn't know where to put this post but...
This is driving me fucking insane... anyone had this shitfuckery? Any auto sparkies got any idea?
Windows up air cycled = no problem
Windows up air in from outside = won't run
Windows down air in from outside = no problem
Put Windows up while air in from outside = stall
Just one window up runs fine
If both the windows are up (regardless of air circulation thing) revs dip if you close the door...
Either window cracked no rev dip
All fuses and relays appear to be intact.
Can't run forscan whipple OS blocks it
Heretic404
Brisbane, Aus
Pete
2018 S550
Also worth adding... issue is intermittent and not guaranteed... only thing that is is the rev dip bs...
fmc_smt
Cottonwood , Arizona
Ground , sounds like a ground issue
Scootsmcgreggor
CA
2016 Ecoboost turned GT
Yeah ground or harness short. Many grounds on this chassis can be bad as the chassis is painted at the ground termination. Detailed techs often sand down the chassis paint for any ground they remove before putting it back. Do this with all grounds on the RF strut tower and ground above the BCM in passenger kick panel and report back.
also seems very odd that you cannot connect to Forscan because of fhe whipple. I’d look further into that. Without access to DTC’s troubleshooting will be very difficult.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Don't matter, as long as the ring terminal isn't painted.
fmc_smt
WildHorse
N/A or GO HOME
Puddintane
'17 S550
And if the retaining bolt is lose , what good what will it be .
Obviously tighten it, but I commented on the 'painted surface'.
fmc_smt
So you did ,but all I stated was to check the grounds , with your paint comment that is not checking a ground .
Scootsmcgreggor
CA
not in all circumstances. I’ve had issues with a ground, tight bolt, which removing the paint resolved. The suggestion was form a 35yr ford tech.
Heretic404
Brisbane, Aus
Pete
2018 S550
Will try (passenger side is drivers side for me) I did notice a lot on unclear contact on the earth's and was thinking it might be related.
No harm in making them better 🤷‍♂️
Can still get to the DTC's without forscan, just can't use forscans fancy Montpelier system to pinpoint anything.
