thePill
Camaro5's Most Wanted
- Aug 13, 2012
- Pittsburgh
- S550
Track Ready is just a marketing term people have gotten use to using. Most of those people are fans of a particular vehicle (or vehicles) that were never intended for track use at all. This would include you fans of big sedans/wagons, small econoboxes and trucks/SUVs and so on. Track is just track, no rules really...
Competition Ready or Race Ready is nearly impossible at the OEM level. Even at the lowest level in the AM circuit, changes need to be made.
One thing I can see needed changed is the front rotors. Anything over 15 inches will need to be down sized to 15 inches (or 380mm) MAX. I am under the impression that the GT350 will come with 15.5 inch rotors in the front, the rear rotors should be fine. Everything else on the GT350 looks to be legal and ready to class. Fluids will likely need changed as well as a more competitive tire. I would also like to shop wheels if the intended class allowed it.
WARNING: Use caution if a Carbon Ceramic Brake upgrade is offered from Ford. The issue will be swapping out the CC brakes for Cast Iron rotors later on. The CC Brakes use a unique calibration and could require extra work or even a new system altogether. Same thing can be said about any Magnetic Ride Control...
