Will the Ford Performance Oil-air separator work with Power Pack 2?
CrashOverride
Under a hood
2015 Mustang GT
I know Ford says it won't fit, but was curious if others were able to tweak it to fit. I know I could go with lots of other ones, but I want it to be an OEM part. I don't want to drop $160 to find out it's not going to work.
Thanks everyone!
ForYourOwnGood
Central MA
2017 Grabber Blue 5.0
Isn't there a separate one that works with a GT350? I think the only difference is the connection on the intake manifold itself.
Monopoly
Toronto
2017 Mustang GT, 2012 Civic Si
Yes it fits. Very tight though. I have pp2 and oil catch can setup.
CrashOverride
CrashOverride
Under a hood
2015 Mustang GT
The problem is that the throttle body adapter sits on an adaptor, and that clocks the GT350 throttle body at a bit of an angle. Because of that, things get very crowded in there, and that's why Ford says it won't work.
But, where there is a will, there is always a way.
ForYourOwnGood
Central MA
Oh yeah the PP2 doesn't have the intake manifold thats right. I've still got my Ford separator in the garage I took off when I did the blower.
Luke17
Poland
2015 GT Roush Stage 2
what about PP3? will it fit voodoo intake?
Brazos609
2015 GT Premium PP Recaro
It should fit perfectly. The PP3 uses the GT350 intake manifold, throttle body, intake tube and airbox so both the driver and passenger side GT350 oil separator should fit perfectly.
Chomorro
San Diego
Philip
2015 Mustang GT 6SPD Premium PP1
I was searching for oil Seperators that fit the power pack 2 and came across this thread. How did you route the vacuum hoses? You didnt have to cut the engine cover and it looks like you clearly have way more space then I do after following the instructions. Have any pics with out the cover?
Monopoly
Toronto
Sorry I sold the car last year and bought a mint S2000. No cutting at all. I just jammed it in there. It was very tight.
The current owned ripped everything out and went with the JLT catch can because of the stage 2 whipple supercharger kit it wouldn't fit at all.
bmrylnd5
@sugoispec
2017 Mustang GT/CS
I just came across this thread and had the same problem. I ended up push clipping the top part and zip tieing the bottom. It fits very snug, but isn't pushing as much on the adapter if I were to try to clip the bottom in. Will monitor over the next few weeks though
txgt
Lewisville, TX
Patrick
2018 Mustang GT Premium 6-speed Manual
@StangTime sells a FP Oil Separator relocation kit that moves everything out of the way. I don’t have the PP2 intake/throttle body but I do have the large Mishimoto radiator which was pushing the coolant expansion tank up against the FP OiL Separator. The relocation kit worked perfectly for me and looks amazing.
accel
'17 GT PP
Thanks everyone!
fits on mine with pp2. i have driver and passenger sides. do not see any reason for fr oil sepatrator not to fit.
Redbaron289
Kentucky
1965 Mustang Convertible, 2019 Mustang GT
I’ve noticed the ones that say it works have a 2017. Has anyone installed this on a 2018 Gen3 and up GT with the Ford Performance Power Pack?
