Will Steeda Short Throw Shifter cure notchy gear change
welsh treg
Mid life crisis guy
Sunny West Wales
Pony power
Looking to fit the Steeda short throw shifter,
Obviously the throw will be improved, but will it help the notchy stock gear change?
Will fit the Bushing bracket kit & transmission mount bushing insert also to complete the job.
Thoughts ?
Aus-MustangGT
Aus-350
Australia
'15 WRX/Evo 8 ADM
Thoughts ?
I had a similar issue with a notchy shifter and I chose to purchase an MGW and it has been one of my favourite modifications. Once the MGW is installed you shouldn't need any other modifications
Centurion07
Hampshire, UK
2015 GT
If getting rid of the notchy change is the aim then just swapping the oil to BG is likely to give you the best result.
I swapped to a Barton shifter and there wasn't much improvement in terms of smoothness IMO. Swapped the oil yesterday and there was a reduction in notchiness and others have reported a big difference by swapping the oil on the stock shifter.
Steeda UK
London, UK
www.steeda.co.uk
Mustangs
Hi Treg,
Our shifter parts should greatly improve your shift experience.
Both Tri Ax short throw and the base bracket are in stock and ready to go (plus of course our new gear knobs and Reverse lockout collars!)
Steeda Mustang Tri-Ax Short Throw Shifter
Steeda Mustang Shifter Base Bushing Bracket Kit
Gear Knobs and Lockout Collars
Here is a great video review of the Steeda Tri Ax vs MGW
[ame="[MEDIA=youtube]Dor-o-5obZA[/MEDIA]"]Steeda Tri Ax vs MGW video[/ame]
Also as mentioned above, making sure you have good quality / fresh transmission oil is also essential for high performance cars. However on a brand new car, that shouldn't really be an issue, unless its been thoroughly cooked.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
This changing to BG oil on mine did make an improvement, I would say not as drastic as some of the other guys make out in the BG thread, but it was for sure noticeable and I'd do it again.
RSCooper on here did the BG and said it might a night and day difference, well worth a try as its not expensive and very easy to do. :)
wildcatgoal
@sirboom_photography
TBD
Same experience here. Not a notch to speak of on my car now.
Does not solve drive train noise, though. No shifter will.
welsh treg
Mid life crisis guy
Sunny West Wales
Pony power
Thanks for the info gentlemen.
Can anyone advise the correct BG oil required, and where can I get it from ?
cheers,
WT
Gibbo205
UK
