involutions
- Sep 27, 2019
- Northeastern U.S.
- Tommy
- 2015 Mustang GT, 2022 Mach 1
Guessing it's normal, but wanted to check with others. My kit has about 600 miles on it. The belt is adjusted as instructed. I don't believe it is too tight or too loose.
After I drive the car for a few miles, not even hard, and pull it into my garage, I can smell hot rubber. It's the belt. I used a infrared thermometer and it's around 175 degrees. The belts on my other cars are only around 120 to 130 degrees.
Can someone else actually measure their pulley temp after a normal drive? If it's fine, it's fine. Just want to make sure. Thanks!
