Whipple 10 rib kit with ati
S550Whipple12
Dallas
2.9l whipple
Went to dyno only put down 642 rwhp with the 3.625 pulley
On the graph up top looked choppy people said belt was jumping
Haven't put the new 6 rib tensioner and spacer on.
If I have to pull whole plate off to put spacer on rather just do a 10 rib
What size pulley would be good with 20% overdrive ati
Engine stock just opt and sprocket
Current mod
Me opg and sprocket
Id 1050x
Kooks 1 7x8 catted
3" cobras sport catback
93 octane
Would like to be at 700 rwhp
Asking because heard lethal suppose to have sale on them next month
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Belt shouldn't be slipping unless something is wrong, 3.625 alone should put you over 700hp with Whipples tune. Who tuned yours?
S550Whipple12
Dallas
2.9l whipple
I don't believe it's tuner fault Lund
I was messing with that far right pulley whipple told me to move all right and belt shot off with the revised tensions
I moved that pulley back to middle and just out old tensioner on
I don't want to take entire bracket off to put spacer on
I will try to get graph put on here literally zig zag up top
gsxr1300
MA
Jason
3.625 with stock sized balancer is the most you can do on 93.
gsxr1300
MA
Jason
Should give you around 12 psi.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
The 6 rib setup is good and doesn't slip according to Dustin at whipple. He claims the 10 rib is mainley for looks and overdrive damper. Boost and Dyno numbers are variables because no boost gauge is dead accurate or comparabl, and either are dynos. Whipple has tested this system so many times and headers and 3.650" pulley makes 700 or above on their Dyno consistently.
esacteksab
CO & KS
2015 Mustang GT
4.0" is the biggest pulley you can get with 10-rib.
With 20% OD damper, it's on the ragged edge for 93.
If you're pump (not E-85), stick with the stock damper. If you have E-85, it comes down to how much risk are you willing to take?
