- May 4, 2021
- Fremont CA 94539
- Eric Chow
- Mustang / Camaro / Corvette
Introduction
A front bumper spoiler, also known as an air dam or front valance, is a component that attaches to the front bumper of a vehicle. Its primary function is to improve aerodynamics by redirecting airflow around and under the vehicle, which can lead to better fuel efficiency and handling. In this blog post, we will discuss the different types of front bumper spoilers, the materials they are made from, and the process of installing one on a vehicle.
Types of Front Bumper Spoilers
There are several different types of front bumper spoilers, each with its own unique design and purpose. Some spoilers are designed to be purely functional, with the sole purpose of improving aerodynamics. Others are more for show and are intended to give the vehicle a sportier or more aggressive appearance. Some spoilers are even adjustable, allowing the driver to fine-tune the airflow depending on the driving conditions.
Materials Used
Front bumper spoilers can be made from a variety of materials, including plastic, fiberglass, and carbon fiber.
Installing a front bumper spoiler on a car is a relatively simple process that typically takes a few hours to complete.
In conclusion, a front bumper spoiler is a component that attaches to the front bumper of a vehicle with the primary function of improving aerodynamics by redirecting airflow around and under the vehicle, which can lead to better fuel efficiency and handling. They come in different designs, such as lip spoiler, splitter, and canard, and are made from materials like plastic, fiberglass, and carbon fiber. The installation process can typically be completed in a few hours. Adding a front bumper spoiler to your vehicle can not only improve its aerodynamics but also give it a sporty and aggressive look.
- Lip Spoiler: One of the most common types of front bumper spoilers is the lip spoiler. This is a small, almost flat piece that attaches to the bottom of the front bumper. It is designed to redirect airflow around the front of the vehicle, which can help reduce drag and improve fuel efficiency. Lip spoilers can also help to reduce lift at higher speeds, which can improve handling and stability.
- Splitter: Another type of front bumper spoiler is the splitter. This is a larger, more complex piece that attaches to the bottom of the front bumper and extends outward. The splitter is designed to create a “low pressure” area under the front of the vehicle, which can help reduce lift and improve handling. Some splitters are also adjustable, allowing the driver to fine-tune the airflow depending on the driving conditions.
- Canard: A third type of front bumper spoiler is the canard. This is a small wing-like piece that attaches to the sides of the front bumper. The canard is designed to redirect airflow around the front of the vehicle, which can help reduce drag and improve fuel efficiency. Canards can also help to reduce lift at higher speeds, which can improve handling and stability.
Materials Used
- Plastic spoilers are the most affordable, but they are also the least durable and can become damaged easily.
- Fiberglass spoilers are more durable, but they are also more expensive.
- Carbon fiber spoilers are the most expensive, but they are also the most durable and lightweight.
- The first step is to remove the factory front bumper, which can typically be done by removing a few bolts or clips.
- Next, the new spoiler is attached to the front bumper using adhesive or screws.
- Finally, the front bumper is re-installed, and the spoiler is adjusted as necessary.
