Nine
- Aug 24, 2015
- Washington
- 2015 GT PP
In November or December I installed a set of BMR sway bars along with a bunch of other stuff. At the time of installation I greased the bushings, and since then I've driven the car maybe 3500 miles and greased them at least one more time (possibly twice.) I went to grease them again the other day and noticed that the passenger side one in the front was split apart and in obvious need of replacement.
I ordered up another set of bushings and swapped it out this past weekend. I read BMR's thread on needing to grease poly bushings, but from the look of my bushing's bearing surface, and the fact that it was greased at least twice in 3500 miles, I'm not thinking it was a lack of grease. You can see in this next pic that there's no melting or smearing inside the bushing, the material looks like it's supposed to:
From the top you can see it split, with the failure going through the area where it fits into the hole for the grease fitting. Is it possible the bushing was just faulty from the beginning?
