Woodshop77
Just wondering what boost numbers people are generating?
Any idea how many lbs/min its flowing at these boost levels?Here is a customers Stage 2 TS log. 40 psi down low, and holding 36 psi at redline no problem...
The Nguage read in InHg so you have to convert that to PSI.
Understood. But what value does this provide honestly? For example, your turbo at 25psi is going to make more power than the stock turbo at 25psi because it flows more. lbs/min is a much more valuable unit of measure.Well since this thread a was direct question about boost pressure, it was filled with a log showing boost pressure. If the person would have asked about lb/min flow which are two completely different things, we would have responded with that. Stage 2 is good for about 55-57 Lb/min, 2+ about 60-62 Lb/Min
Agreed, also on the flip side it makes more power at a lower PSI which makes it more efficient and possibly working less to do it.Understood. But what value does this provide honestly? For example, your turbo at 25psi is going to make more power than the stock turbo at 25psi because it flows more. lbs/min is a much more valuable unit of measure.
Pretty sure that is exactly what I said above. What good is answering somones question? As far as that, you will have to ask them if the answer was satisfactory. It would seem you like to argue. Feel free to do it elsewhere.Understood. But what value does this provide honestly? For example, your turbo at 25psi is going to make more power than the stock turbo at 25psi because it flows more. lbs/min is a much more valuable unit of measure.
This is a forum for people to learn. It seems by the OPs original question that there is a lack of complete understanding in regards to how turbo systems work. Asking how much boost people are running doesn't provide much information at all. You answered the original question that doesn't provide much value and then I responded by asking a more informative question about airflow numbers. Not sure what was wrong with that? If anything, I prompted an opportunity for you guys to showcase what your turbo can do. Instead, you came off as defensive...Pretty sure that is exactly what I said above. What good is answering somones question? As far as that, you will have to ask them if the answer was satisfactory. It would seem you like to argue. Feel free to do it elsewhere.
Yes, this is why I originally posted this " Boost level is different than flow. They are two completely different things. Boost is simply the reading of restriction air NOT getting into the motor. If you improved flow of the motor you would continue to make more power at lower boost until the turbo could no longer flow. These turbos are rated for about 600hp at the crank flow wise. This does NOT take into account engine efficiency. "This is a forum for people to learn. It seems by the OPs original question that there is a lack of complete understanding in regards to how turbo systems work. Asking how much boost people are running doesn't provide much information at all. You answered the original question that doesn't provide much value and then I responded by asking a more informative question about airflow numbers. Not sure what was wrong with that?
