Wavetrack Replacement Differential
beefcake
Bethel
2018 Ford Mustang
With seeing a couple guys go through these recently, Wavetrac has stepped up to the plate to offer an alternative to the factory differential.
Wavetrac Ford 8.8" torsional differential fits the 2015 Mustang GT and Ecoboost models. This is the only torsional differential manufactured that works in No or Near No-Load conditions. All Wavetrac differentials include a transferable, Limited Lifetime Warranty. Wavetrac only recommends the following aftermarket fluid: 75W90 Motul Gear 300 (100118) or 75W140 Motul Gear Competition (101161).
Application: 2015 Mustang GT/V6/Ecoboost
Wavetrac Features:
• Innovative: Patented Wavetrac design automatically improves grip in low traction conditions. This feature is truly innovative and unlike any other torque biasing diff design.
• Premium Materials: 9310 steel gears run in case-hardened billet steel bodies. ARP fasteners used throughout.
• Maintenance Free: As supplied new, the Wavetrac differential will perform a lifetime of service without maintenance or rebuilds.
The Wavetrac is the only differential that can automatically add more load internally when it’s required. In the case where both wheels are on the ground during zero axle load, such as during a transition to deceleration, the Wavetrac device is able to prepare the drivetrain for when the zero torque condition stops, eliminating the delay seen with ordinary gear diffs. What this means for you as a driver is that power is delivered to the gripping wheels for more time and in a more constant manner making you faster and improving stability. The Wavetrac truly is different - and its innovative features can make a real difference in your car’s performance.
Now available!
http://teambeefcakeracing.com/56-309-165wk.html
