Water leak glove compartment
1st time Mustang
New Jersey
2015 Gt.Auto.Premium.3.55
Anyone getting a water leak in glove compartment that drips to the passenger side mat
jasonstang
Denver, CO
2017 GB GT/CS 6MT
AC drain hose clogged?
Check your air cabin filter and associated compartment.
racer24crm
Philadelphia
Chase
2015 Ruby Red GT
I wonder if this is similar to the problem the last gen mustangs had. There was a drain hole underneath the windshield cowl where the cabin filter was. it would get clogged with dirt, leaves, etc. and cause water to leak into the cabin. Happened to me on my 05 once. Just lifted the cowl and unclogged it. Does you car sit outside a lot or is it garage kept?
1st time Mustang
New Jersey
Outside..I'll try your advice..Thanks
racer24crm
Philadelphia
Chase
2015 Ruby Red GT
I just checked out where the location of the filter is and its been moved into the glove box. Don't know if there is gonna be a drain hole underneath the cowl now but it might be worth a look. Hopefully, you won't have to remove the wipers to reach in. Maybe take the filter out first and feel around for drain holes behind it.
1st time Mustang
New Jersey
I just hosed down the car on that side for about 15 minutes simulating a rain shower.. not a drip of water.. go figure. If it happens again I will bring to the dealer thank you for your suggestions greatly appreciated
When you did the above exercise - was the car on level ground?
I would try it again with car parked on a slope (so rear of vehicle is sloped downhill). You may get some results since the path of the water will drain backwards towards windshield and cowling.
1st time Mustang
New Jersey
My driveway is slightly sloped downhill.Thankyou
