Vibration problem 50+ mph ?HELP!!
Nos-pete
Cali
Pete
2018 mustang GT 5.0 A-10 Whipple Charged 989 RWHP....2020 Shelby GT500
2018 GT 10r80 E-85 Have had an aluminum driveshaft for about a year when removed got slight vibes had it clocked 180 degrees and went away perfectly. Recent install brand new Ford performance torsen and 4:09 gears also Ford performance...since the gear and torsen install have a vibration 60+ mph I've went as high as 80mph and clocked it 180 degrees many times since and won't go away any suggestions?? Please help. Maybe torsen and 4:09s not compatible??
kent0464
Virginia
Kent
1983 Ford Ranger, 1986 SVO Mustang, 2017 Mustang GT PP, 2017 F150 3.5 Eco
Gears- ring and pinion are more than likely not going to cause vibrations neither will the Torsten center....if they are installed wrong they’ll make weird noise; clunking, whine or growl, etc.
The first thing I would check would be the IRS cradle mounts/bolts etc, if all that is good then check the axle nuts for the rear wheel bearings and the U-joints on the aluminum drive shaft.
