Advertisement
v3.3 > v3.4 not liking the "blue night theme"
Min Ahn
Posts
113
Los Angeles
Min
2019 Mustang Ecoboost Premium
Ford Sync v3.3
Ford Sync v3.4
Is there any way I can apply the old night theme that v3.3 had?
Perhaps altering the vehicle code to other Ford model on Forscan?
EDIT:
Looks like Escape's v3.4 night mode is as above. Will try Escape's code on Forscan later!
Elp_jc
Posts
2,195
El Paso, TX
JC
2019 Bullitt K7979, MR, Nav, B&O, Cover
That's actually a Lincoln code, but the good news is I have it, and looks immensely better. I actually have night mode permanently with the 2nd background choice (you can do that with 3.4, and still dims at night), since the contrast with the lower buttons is better (a darker gray). All themes are blue, except a gray and a brown, which are Lincoln... but you can try all of them (0-9), if you want, like I did. Anyway, here's what you need to do to have the gray theme posted above:
APIM 7D0-01-02 8xxx xxxx xxxx This changes the brand from Ford to Lincoln
APIM 7D0-03-01 xxxx x2xx xxxx You can play with all the other numbers, if you want.
I'd also strongly recommend these 2 more changes, since you're already there :) :
APIM 7D0-02-03 xCxx xx This enables the 'calm screen', which shows date, time, etc.
APIM 7D0-02-01 xxxx 10xx xxxx This enables the Ford Performance screen animation, which is immensely better than the crappy blue Mustang one. After this, no more blue on your screen anywhere :). Hope this helps.
JC
Min Ahn
Posts
113
Los Angeles
Min
JC
Succeeded! I recognize your username from the big Forscan thread because I was just messing with the reverse tilt mirror, too while I was there to change the theme lol. Failed but good attempt, was fun! Thanks :)
Elp_jc
Posts
2,195
El Paso, TX
JC
Succeeded!
Cool; glad I could help. Try the night mode with a lighter background (you have 3 choices, plus the default black); looks much better. That mode has almost no contrast with the buttons below, but at least it's not freaking blue. Ha ha. Night mode as described above fixes that :).
Advertisement
Advertisement
Advertisement
