Urgent! Mustang died while driving...
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
Cruising at 35 mph
TC & steering light came on.
Message center displayed "Steering Assist Fault" and "see dealership for service"
Tach went to 0 (engine cut off)
Interior door locks won't respond, Interior trunk button won't respond.
Fob lock/unlock has no response. 2x trunk button will make lights flash, but trunk stays latched (this is the most response I can get from anything)
I've disconnected the battery and waited. Situation remains the same.
I'm very glad I wasn't on the highway. Had to push into a parking lot. I can't even lock the passenger door.
Has anyone had anything like this happen? I've disconnected the battery for the night. Tomorrow I'll try to start it again, but I'm not holding my breath.
16Fastback
RMR 8985
Pennsylvania
Stephen
2016 Fastback , 2009 Ranger 4x4
Not saying this is the problem but when my battery had a bad cell (low voltage)it did all kind of funky shit.
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Yeah, when the battery in my '16 went bad, it was all kinds of crazy, like in some sort of limp mode, would barely accelerate - then all sorts of traction/ABS error messages, just totally flipped the f*** out.
RaceHorseV8
Illinois
Ricky
2001 Cobra, 2004 Cobra, 2019 GT
Another vote for battery issue. I've had the same crazy stuff happen when the battery started to go bad. The thing to remember is things that have low current draw might still work like the lights that still flash. If a cell has shorted you lose the ability to deliver higher current flow. If you don't see ~13.2 volts DC you probably have a bad battery. The meter only needs a trickle of current to work. Auto parts stores will run a free stress test for you if in doubt. Good luck!
MaskedRacerX
Driver
Vilano Beach, FL
DT
Side note if it is the battery: I went through Batteries Plus, not sure if you have those in your area. It's easy to find a 15% coupon for a Duracell that's an exact fit/spec for the S550, order online, pickup from the store, take in the old battery and walk out with your core charge already credited.
TexasRebel
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
Thanks for the responses!
I'm about to head out with the pickup and pull the battery. If that's the issue it seems easier than trying to set up my laptop and OBD2 scanner in a parking lot.
TexasRebel
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
Update:
I went ahead and changed the battery out since it's over 3 years old. No change.
As I was locking everything up to go form a new plan, I manually locked the passenger door, shut it and tried the handle. Since I have the key in my pocket the doors unlocked!! I tried the engine and it started, and got home.
Puzzling.
There is a DTC stored and the wrench is lit up. I'm going to check that now.
16Fastback
RMR 8985
Pennsylvania
Stephen
Update:
Puzzling.
Glad you got it home,best of luck getting it resolved
Brent Davis
Northern Virginia
2018 Shadow Black Premium Mustang GT
For some reason the clutch starter switch right below the clutch pedal can go bad. It Somehow is in line with your car starting and/or cutting off if bad. It’s not an exp naive item from the dealer either. Just something else to check after a battery replacement.
TexasRebel
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
DTCs on record:
APIM:
U0151 - Lost Communication With Restraints Control Module
U0238 - Lost Communication With Digital Audio Control Module D
U0452 - Invalid Data Received From RCM
BdyCM:
P0230:12-88 - Fuel Pump Primary Circuit - Circuit Short to Battery
U3006:16-08 - Control Module Input Power A - Circuit Voltage Below Threshold
B1438:03-08 - Battery Current Sensor - Frequency Modulated / Pulse Width Modulated Failures
FCIM:
U0452:82-08 - Invalid Data Received From RCM - Alive/Sequence Counter Incorrect/Not Updated
B1C83:14-08 - Heated Rear Window Relay Coil Circuit - Circuit Short To Ground or Open
B105A:14-08 - Cabin Temperature Sensor Fan - Circuit Short To Ground or Open
ABS:
U300A:29-28 - Ignition Switch - Signal Invalid
Freeze Frame :
-GLOBTIM: 115187907 sec - Global real time
-TOTDIST: 125699.0 km - Total Distance (78106 mi)
-OUTTMP: 28 °C - External Temperature From Sensor
-POWER_MODE: Ignition on power mode - Power Mode Status
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-VPWR_ABS: 12.30 Volt - Module supply voltage
-VSS: 57.0 km/h - Vehicle Speed (35.42 mph)
SCCM:
B1131:08-08 - Wiper Motor Module - Bus Signal/Message Failures
IPC:
U0401:81-08 - Invalid Data Received From ECM/PCM - Invalid Serial Data Received
U0415 - Invalid Data Received From ABS Control Module
U0420:82-08 - Invalid Data Received From PSCM - Alive/Sequence Counter Incorrect/Not Updated
This makes it seem like either the battery was the culprit and it just took a little while for everything to start working again with the new one... Or I have a bad connection/short in a harness somewhere that jarred loose when I shut that door. I'm going to assume the first unless things start happening more often.
Mghoward74
San Diego
Greg
S550
Did you tune the car before you had issues?
