Thub
- Mar 7, 2018
- Elgin, Illinois
- Jim
- 2018 GT 6 speed
I've gone through a lot of brake parts since I got my 2018 base GT, with the black accent package, which comes with 255/40/19 tires. and I figured some people might like to hear my thoughts on things.
Stock base GT stuff
My stock pads were totally destroyed by my first track day. I boiled the fluid a bunch of times, wore a lot of the pads away, and the trailing edge of the front pads ended up falling off entirely. (That was really scary to find after I drove home from the track)
Powerstop Z26 Base GT parts
I ended up replacing everything with the powerstop Z26 kit with their drilled and slotted rotors, and I was happy with those parts, dust is crazy low, but I learned there's no way to properly cool the rotors, and since I planned on a lot more track days, I knew the Brembos were gonna be necessary.
I did some testing before I remove these parts and on the stock tires, I saw 0.99G on the Track Apps accelerometer and my phone gave me about 1.04G (My phone was level with the car stopped, but with brake dive I expect it to read a little higher. The rear wheels locked much quicker than the fronts as well.
Brembos with stock pads (Z26 out back)
I read Vorschlag's entire thread on their base 2018 car, and decided I didn't believe them about the master cylinder. (Actually I figured if it did suck, I'd be able to swap the MC out before my first track day).
I bought myself some gently used Brembos and braided SS lines. and used the OEM brembo pads to start.
The stock pads are way too grabby for my tastes, and dust like crazy, but I was happy with the ultimate braking force
Brembos with Powerstop Z26 pads
I got sick of the dust and excessive grabbiness from the OEM brembo pads really fast,The rotors I had were only about 0.010" thinner than brand new, so I left them on the car, The dust is almost entirely gone, and the brakes are much easier to modulate around town, so I'm much happier, but I got to thinking about the ultimate braking force. After all, Vorschlag said he saw much worse braking distances with the brembos.
I didn't see that at all. I got 1.10 on the track apps page, while my phone's accelerometer read 1.159G. The rear wheels still locked first, but much closer to the fronts. The extra weight transfer from the higher G force made the rear end feel really light, and I had to steer under braking to stay straight.
My personal conclusion is that the stock master cylinder is satisfactory for handling either caliper set, though I'm sure my pedal is a little lower than the PP master cylinder would be, but I'm ok with it, the brake pedal is basically even with the gas pedal while braking, so heel-toe downshifting is easier.
I've got some Powerstop trackday pads for the track, which I haven't put on, so I'll update after my first trackday for the year.
TLDR in bold, I'd be happy for this to become a discussion.
Stock base GT stuff
