UK spare wheel?
Myweepony
Aberdeenshire
Phil
Mustang GT Auto
I do; but I'd call the RAC anyway unless I'm in a car park or similar.
Exactly! It's all about having options. I wouldn't be changing wheels on a busy carriageway either. But if you can get to a place of safety, why not.
It's a bit like Kapiteins go faster bits. Probably cost a few thousand, not much use if you're parked up at the side of the road though.
Where as spend a few hundred, just the once, and it gives you the option to go somewhere. There's some roads up here where you might be lucky to see another car in 5 hrs, let alone 5 mins. Would I rather have a go faster bit or a spare wheel. Hmmmmm. No offence meant Kapitein.
Mustang Cally
Nottingham
Mark
2013 Insignia 1998 Land Rover 110
Should I have a can of tyre gunk supplied?
It's just occurred to me I've never seen one, I know there's a compressor but I don't recall any gunk...
Myweepony
Aberdeenshire
Phil
Mustang GT Auto
The can of gunk should be attached to the compressor. It is selectable, either gunk and air or just air.
The gunk has a shelf life though.
Kristian87
Super Moderator
Moderator
Newbury, UK
Mustang GT
[MENTION=14295]Kristian87[/MENTION] had the flat and gunked it. got it repaired. I had a split rubber, the kind that'd cause a pregnancy.
Not quite true. I did fill the punctured tyre with gunk, which allowed me to drive the 20 miles to Ford who robbed me of £210 for a new tyre. Ford were reluctant to do the repair after it has been filled. Still have the tyre though.
Note that I didnt use the ford kit in the boot. I got one of those cans from Halfords that did the job quite well. I saved the gunk in the boot. I also note that the inflator thing was pants, couldnt hold the pressure so wouldn't inflate the tyre after gunk!
MikeR
Mild Wild West Berkshire, UK
'17 GT Convertible Auto Magnetic Euro PP Custom Pk
The Automotive Authority solution is now shipping - a correctly sized wheel which will fit over the larger brakes AND also in the spare wheel well has been a long time coming. It has the same rolling diameter as the GT rears so will not strain the limited slip diff when in use on the rear. Details and video at:
https://www.automotiveauthorityllc....-2015-2017-ford-mustang-gt-with-brembo-brakes
Mine arrived today and it fits in the boot beautifully. I'll do a test fit on the car in the next day or two when the temperature increases by a few degrees.
Its not cheap with UK shipping, tax and duty and may not be for everyone, but for me the thought of touring in Europe and suffering an unsealable puncture on an Alpine pass requiring recovery and VOR while sourcing a new tire makes it worthwhile.
antijam
Glos. U.K.
Nick
2016 GT cabriolet
Thanks for the info. Can you give an idea of the total cost to import to the UK?
MikeR
Nick, best to go through their ordering process up to the payment method to get an accurate quote as the prices have changed. I placed my order back in May of this year before the product was even available and received a pre-order discount at that time. Automotive Authority seem very 'active' with their discount codes so I'd suggest registering on their site to get a current one. Shipping to the UK has gone up too. Then there is customs duty, VAT and ParcelForce's clearance fee too. Depending on the prevailing exchange exchange rate you are going to be looking at £400, or so, delivered.
I did consider buying and carrying a spare stock Mustang GT wheel and tyre but that does not fit neatly into the spare wheel-well. As I am hoping never to have to get this thing out, I did not want to lose any boot space from my convertible on a permanent basis.
MikeR
Then the early birds got the worm :D !
USPS worked well and is (nearly 3 times) less expensive than their UPS option.
antijam
Glos. U.K.
Nick
2016 GT cabriolet
Well I bit the bullet and received my wheel today - just 18 days after ordering. Total cost after import and handling charges - even with discount - £569.28. Expensive for a spare wheel, but perhaps not for peace of mind?
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
